Thread Closed
equation x^2+y^2+z^2=1
Share Thread
Oct11-09, 09:05 PM   #1
Optimize f(x,y,z) = x3 + y3 + z3, subject to the constraint g(x,y,z) = x2 + y2 + z2 - 1 = 0
Step 1:
I did L = f - [tex]\lambda[/tex]g = x3 + y3 + z3 - [tex]\lambda[/tex](x2 + y2 + z2 - 1)
Step 2:
I got Lx = 3x2 - 2[tex]\lambda[/tex]x = 0, Ly = 3y2 - 2[tex]\lambda[/tex]y = 0, Lz = 3z2 - 2[tex]\lambda[/tex]z = 0
Now I can't seem to solve these 3 equations to get the critical points & find what [tex]\lambda[/tex] is. Some help please. Thanks.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Oct12-09, 03:06 AM   #2
Remember that you also need to use the equation x^2+y^2+z^2=1 to solve for lambda...
even though you used this equation in your lagrangian, the "=1" part kind of gets washed away when applying the E-L equations, and you need to introduce it back into the system of equations in order to find a solution.
Oct12-09, 04:40 PM   #3
Alright. 3x2 = 2[tex]\lambda[/tex]x, 3y2 = 2[tex]\lambda[/tex]y, 3z2 = 2[tex]\lambda[/tex]z
[tex]\Rightarrow[/tex] 3/2x = 3/2y = 3/2z [tex]\Rightarrow[/tex] x = y = z
Putting this into the constraint [tex]\Rightarrow[/tex] x2 = 1 so x = [tex]\pm[/tex]1, y = [tex]\pm[/tex]1, z = [tex]\pm[/tex]1, I got 8 critical points (1,1,1), (1,-1,1),(1,1,-1),(1,-1,-1),(-1,1,1),(-1,-1,1,),(-1,1,1) & (-1,-1,-1). Putting x = y = z = [tex]\pm[/tex]1 to find [tex]\lambda[/tex] I get [tex]\lambda[/tex] = 3/2 for x, y & z. Is this right? I'm pretty sure it is. Then I just use the reduced hessian to find the nature of the critical points (Max, min or saddle).
Oct12-09, 04:46 PM   #4
Quote by squenshl View Post
I think you made a mistake when putting the equations back into the constraint...
with x=y=z, you should get 3x^2=1 (not x^2=1) which will give you factors of 1/Sqrt(3) in your answer.
with the equations you have written out i think lambda ends up being Sqrt(3)/2
Oct12-09, 05:03 PM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
DO NOT DIVIDE WITH POTENTIAL ZEROES!!.
You have the 4 equations:
[tex]x(3x-2\lambda)=0[/tex]
[tex]y(3y-2\lambda)=0[/tex]
[tex]z(3z-2\lambda)=0[/tex]
[tex]x^{2}+y^{2}+z^{2}-1=0[/tex]
Consider the case x=0:
This gives you an additional 3 cases:
a) y=0, z something else
b) z=0, y something else
c) Neither z or y 0.
Thus, since this can be copied for the two other variables as well, you'll have a lot more critical points to consider
EDIT:
Furthermore, since those points you found REQUIRED x=y=z, then evidently a point like (-1,1,1) couldn't possibly work, right?
FURTHERMORE:
Don't bother about the Hessian; too much trouble!
You ought to be able to see which of the solutions represent optimizations of f
Oct12-09, 06:00 PM   #6
Sorry. The constraint was x2 + y2 - z2 - 1 = 0. My bad. So I think my answers are right.
Oct12-09, 06:05 PM   #7
Nope, you are right. It is x = y = z = 1/sqrt(3). Am I right to say there are 8 critical points.
Oct12-09, 06:09 PM   #8
well if the constraint is the one you gave us the second time, then indeed you should not get x=y=z=1/Sqrt(3). Check your L_z equation again...
regardless, arildno is correct in that you must cover your bases and watch your divisions by 0 here.
Oct12-09, 06:14 PM   #9
It is x = y = -z
So x = y = -z = [tex]\pm[/tex]1/[tex]\sqrt{3}[/tex]
Oct12-09, 06:16 PM   #10
NO, here you have x=y=-z and x^2+y^2-z^2=1 which leads to 2x^2-x^2=1 and thus x=1,x=-1. HOWEVER, notice that this is in the case that x,y,z<>0.
Oct13-09, 02:35 AM   #11
Recognitions:
Is your constraint:
a) [tex]x^{2}+y^{2}+z^{2}-1=0[/tex]
OR
b) [tex]x^{2}+y^{2}-z^{2}-1=0[/tex]
Furthermore, it does not seem that you understand that you cannot divide by zero.
Oct13-09, 02:29 PM   #12
Oct13-09, 03:44 PM   #13
Recognitions:
In that case, you have the 4 equations:
[tex]z(3z+2\lambda)=0[/tex]
A) Suppose that neither x, y or z are 0.
Then, we get x=y=-z.
Inserting this into the last equation yields:
[tex]x^{2}-1=0\to{x}=\pm{1}[/tex]
Thus, we get TWO critical points, namely (1,1,-1) and (-1,-1,1)
B) Suppose that x=z=0
Then, we get from the last equation:
[tex]y^{2}-1=0\to{y}=\pm{1}[/tex]
Thus, we get TWO critical points, namely (0,1,0) and (0,-1,0)
C) Suppose y=z=0.
Then, in analogy with B, we get the critical points (1,0,0), (-1,0,0)
D) Impossible cases:
Assume that x=y=0. Then the last equation reads -z^2-1=0, which has no solutions.
Furthermore, assume x=0, neither y or z 0. Then y=-z, and the last equation reduces to -1=0, which is false.
Similarly for y=0, neither x or z 0.
E) z=0, neither x or y 0.
Then, x=y, and the last equation becoms:
[tex]2x^{2}-1=0\to{x}=\pm\frac{1}{\sqrt{2}}[/tex]
This yields the last two critical points:
[tex](\pm\frac{1}{\sqrt{2}},\pm\frac{1}{\sqrt{2}},0)[/tex]
Thus, in total, we get 8 distinct critical points, to be found in A), B), C) and E).
Thread Closed
Similar discussions for: equation x^2+y^2+z^2=1
Thread Forum Replies
LaGrange multipliers! Calculus & Beyond Homework 8
Lagrange Multipliers Calculus & Beyond Homework 3
lagrange multipliers Calculus 3
Lagrange multipliers Q Calculus & Beyond Homework 7
Lagrange Introductory Physics Homework 0
