Thread Closed
velocity of a satellite in an elliptical orbit
Share Thread Thread Tools
Oct12-09, 01:51 AM   #1
see attachment #12.106
2. Relevant equations
V=R[tex]\sqrt{}(g/r)[/tex] (for a circular orbit)
where R is the radius of the earth and r is the radius of the orbit from the center of the earth
conservation of momentum for elliptical orbits:
Vara=Vbrb
3. The attempt at a solution
The first thing I did was find the velocity of the satellite while it is still in a circular orbit and came up with 1.46x108 m/s. Now this is fine and dandy but I don't see where there is enough information to get the velocities in the elliptical orbit since the only equation I have for an elliptical orbit is listed above and I don't have Va or Vb. I tried to pretend that the object also went into a circular orbit at B by another rocket boost. Hoping that I might be able to solve for something but to no avail. So I guess my question really is, what is another equation that also has Va and Vb so I can solve simultaneously, or is there a way to eliminate one of the variables that I don't see?
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Oct12-09, 10:24 AM   #2
Recognitions:
Homework Helper Homework Help
Quote by ehilge View Post
Vara=Vbrb
Thanks!
Angular momentum is conserved. So, [itex]m\omega r^2 = constant[/itex] or as you have noted, Vara=Vbrb.
You have Va and ra. What you need to find is rb - the effective radius at the farthest point. Would that not just be the distance from the centre of the earth? Be careful about translating radius from altitude.
AM
Oct12-09, 10:32 AM   #3
D H
Mentor
[b]conservation of momentum for elliptical orbits:
Vara=Vbrb
This in general is not true for elliptical orbits. Conservation of momentum says [itex]\mathbf r \times \mathbf v[/itex] is constant. This is the vector cross product; the radial component of velocity is not involved in this expression. For elliptical orbits, the radial component of velocity is zero at two points: apogee and perigee. Thus [itex]r_av_a = r_p v_p[/itex] is valid.
Oct12-09, 01:43 PM   #4
Recognitions:
Quote by D H View Post
Yes. The angular momentum is the tangential component of velocity divided by r. The confusion is avoided if one uses [itex]m\omega r^2 [/itex] for angular momentum.
AM
Oct12-09, 01:44 PM   #5
Quote by Andrew Mason View Post
AM
first off, I realize that the radius at the furthest point is the altitude above the earth + radius of the earth, and I have factored this into my calculations.
Secondly, I do not have Va of the object in the elliptical orbit, only in the original circular orbit. And I need to find the increase in speed the object makes at A while in a circular orbit to project it into an elliptical orbit. This is the part that I don't understand because I have two unknowns with the one equation.
ok, fair enough and good to know. However, the points I am considering in the problem are at apogee and perigee, so the original equation I had is valid, right? And I still have the problem of having one equation with two unknowns. Any ideas on how to resolve that?
Thanks for your hep!
Oct12-09, 01:54 PM   #6
D H
Mentor
Well there's always the conservation laws. You've already used conservation of angular momentum. What else is conserved in an orbit?
BTW, beware that the question used altitudes, not distances from the center of the Earth. You might find the latter to be a better choice. For example, in [itex]r_av_a = r_p v_p[/itex].
Oct13-09, 12:24 PM   #7
Recognitions:
What is the change in potential energy of the satellite in moving between A and B? Does that help you determine the relationship between speeds at A and B?
AM
Oct13-09, 03:08 PM   #8
I managed to find another equation that I can use
1/rapogee+1/rperigee=2GM/h2 = 2(gR2)/(raVa)2 = 2(gR2)/(rbVb)2
I used this to find the velocity at A, and then calculated everything else from there using the previous equations.
I suppose I could also have used conservation of energy though
KEA + GPEA = KEB + GPEB
.5mvA2 + mgha = .5mvB2 + mghB
mass cancels out and I have another equation with va and vb
Thanks for your help!
Oct13-09, 03:46 PM   #9
Recognitions:
You have to explain where this formula comes from. Consider:
[tex]\Delta KE + \Delta PE = 0[/tex]
[tex]1/2(mv_A^2 - mv_B^2) + (-GMm/r_A + GMm/r_B) = 0[/tex]
[tex]v_A^2 - v_B^2 = 2(GM/r_A - GM/r_B)[/tex]
From the conservation of angular momentum:
[tex]v_Ar_A = v_Br_B[/tex]
so you can solve for vA
AM
Thread Closed
Thread Tools
Similar Threads for: velocity of a satellite in an elliptical orbit
Thread Forum Replies
Circular orbit VS Elliptical orbit?? Differences? Introductory Physics Homework 2
Escape velocity FROM a satellite in orbit? Introductory Physics Homework 4
Elliptical Orbit Introductory Physics Homework 1
Position as function of time - satellite in elliptical orbit (spherical coordinates) Astrophysics 0
Elliptical orbit Introductory Physics Homework 2
