Work Energy Theorem, Kinetic Energy, and Tension
The discussion revolves around a problem involving the work-energy theorem, tension in a cable, and kinetic energy, specifically in the context of a rescue helicopter lifting a person. The scenario includes calculating the tension required to lift a person with a given mass and acceleration, as well as determining the work done by that tension over a specified distance.
  • Mixed
  • Participants explore the application of Newton's Second Law and the work-energy theorem to find the tension in the cable and the work done. There are attempts to calculate the tension based on weight and acceleration, with some participants questioning the assumptions made about forces acting on the person.
The discussion is ongoing, with participants providing guidance on the relationship between tension and weight, as well as the net forces involved. There is an exploration of different interpretations of the forces acting on the person, and some participants are attempting to clarify their understanding of the concepts involved.
Participants are working under the constraints of a homework problem, which may limit the information available and the methods they can use. There is a focus on ensuring that the upward force (tension) exceeds the downward force (weight) to achieve the desired acceleration.
IAmSparticus
1. A rescue helicopter lifts a 90 kg person straight up by means of a cable. The person has an upward acceleration of 0.70 m/s2 and is lifted from rest through a distance of 10 m. What is the tension in the cable and how much work is done by the tension in the cable? Use the work-energy theorem to find the final speed of the person as well.
2. Work Energy theorem: Wnet = (1/2 mass velocity final^2) - (1/2 mass velocity initial^2)
Tension: T = mass gravity
3. Tension: mass gravity
T = 90 kg * 9.8 m/s^2
T = 882 N
Which is wrong according to Webassign.
WET = Delta K
WET = (1/2 mass velocity final^2) - (1/2 mass velocity initial^2)
Not sure how to go about solving this part. I guess the masses cancel, but what next?
T = 882 N
It's no surprise that that is wrong. Remember that the person is accelerating upwards. This means that there is a net upward force on him. If the tension is only just balancing his weight, then obviously the net force is zero, and he won't be accelerating. If that's not clear, then you need to review Newton's 2nd Law.
Ok, so I tried using Newtons Second Law, Force = mass * acceleration, and now I got 63 N, which is apparently still wrong.
Yeah, that's the NET force which is pulling him upwards. Draw a free body diagram for the person, and you'll see that two forces are acting on him, namely his weight downwards, and the force due to the tension in the cable, upwards. You add the two forces acting on him together (taking direction into account) to get the net (total) force on the person. The upward force (tension) must **exceed** his weight by 63 N in order for there to be a NET upward force of that amount accelerating him upward. Do you understand?
I think I understand, so would the net force be -9.1 m/s^2 * 90 kg which would equal -819 N?
No. Did you draw a free body diagram for the person like I suggested?
T is pulling him upwards.
Weight is pulling him downwards. Let's call the magnitude of the weight W. Then the weight is -W.
To find the net force, add the two forces that are acting on him:
T + (-W) = T - W = Fnet = +63 N
For T - W to be positive, T must be greater than W. In other words, the force pulling him upwards is greater than the force pulling him downwards, so that the force pulling him upwards "wins." This is what we mean when we say that there is a NET upward force on him. "Net" = the direction and magnitude of the end result, after all forces have been considered.
T - W = 63 N.
You know what W is.
W is equal to the weight, which is the gravitational force times the mass, so -9.8 m/s^2 * 90 kg... which is -882 N. Correct?
Yeah, that's correct. Now, as I've stated before, the strength of the force pulling him upwards must be greater than that (in magnitude) by 63 N.
So I add 63 N to -882 N to get -819 N? Or is it positive 819 N since it is in the opposite direction of the weight? Or would it be 945 N since that is what 63 N + 882N (the opposite of the weight) equals?
There is only one of those possibilities that makes sense (the third one that you wrote). I am going to tell you the reason for the fourth time: the force pulling him upward has to be larger (in magnitude) than the force pulling him downward in order for him to be moving upward.
One way to think of it:
T - W = 63
T - 882 = 63
T = 882 + 63
Just think of it in terms of magnitudes (ignoring direction). The *magnitude* of the weight is 882 N, and the magnitude of the tension is 63 N larger than that.
So the work done by the tension would be equal to the force times the displacement, or 945 N * 10 m, which would equal 9450 J?
Sounds about right to me!
So then to find the final speed of the person I'm supposed to use the work energy theorem which will help me find the change in kinetic energy which is [ (1/2 mass velocity final^2) - (1/2 mass velocity initial^2) ]?
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 19 ·
  • · Replies 56 ·
