What are the values of a that make A=0?
  • Thread starter Thread starter ~Sam~
To determine the values of 'a' that make the determinant of matrix A equal to zero, cofactor expansion is suggested as the method of approach. The matrix A is given as a 3x3 matrix with variable 'a' in multiple positions. Participants express confusion about how to apply cofactor expansion effectively in this scenario. The discussion emphasizes the need for clarity in the calculations involved in finding the determinant. Ultimately, the goal is to identify all values of 'a' that satisfy the condition A=0.
~Sam~
if
A=
a 3 5
a -7 6
5 4 a
find all values of a that make A=0. Give your answer as a comma-separated list.
Looks like the cofactor expansion would be used
I'm really lost in this one.
What did you get by using it?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
