Number theory. numbers of the form 111 111.
cap.r
consider the number m=111...1 with n digits, all ones. Prove that if m is Prime, then n is prime
def of congruence. fermat's and euler's theorem. can also use σ(n): the sum of all the positive divisors of n, d(n): the number of positive divisors of n, φ(n): Euler's totient function φ, counting the positive integers coprime to (but not bigger than) n
I managed to prove that every odd prime except 5 divides on of these numbers.
3|111 so let's look at P>5 which do not divide 10.
now all such numbers can be represented by \frac{10^(^P^-^1^)-1}{9} using fermat's theorem I can say this is congruent to 0(mod P). so now every prime P that i plug into this will give me a one of these numbers. obviously it doesn't work with non primes since we used fermat's little theorem.
so now i don't know what to do exactly... if m is prime then i know it's not one of these numbers and the sum of it's digits is odd. but i am stuck.
Your attempted solution ("I managed to prove that every odd prime except 5 divides on of these numbers." and so on) doesn't really address what you need to prove. Try a proof by contradiction. Observe that
m = \frac{10^n - 1}{9}
The hypothesis is that m is prime. Now assume that n is composite and derive a contradiction.
Let me know if this suggestion isn't clear, or if you'd like more help.
Petek
I am afraid I don't see it... here is what I have the critical step is missing.
let m = \frac{10^n - 1}{9} assume m is a prime with n digits.
now i assume n is not prime so n = P1k1*...*Prkr so now m=((10^P1k1)^..^Prkr-1)/9
since m is prime...
sorry i couldn't get it to show up right in latex.
Look at it this way. If n is not prime, then there is a k that divides n. Then doesn't 11...1 with k ones divide m? You can write out the factorization.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
