Thread Closed
Conservation of Mass
Share Thread Thread Tools
Oct26-09, 09:50 AM   #1
Simple question:
Rest Frame: In their respective rest frames, the following objects have the following rest masses: Object A Mass = 1 kg ; Object B Mass = 1 kg. Total Rest Mass of system: 2 kg.
A & B accelerate and reach some constant Velocity. At this velocity, their relative masses are determined to be 1.5 kg each. They head straight at each other and collide. Their collision is perfectly inelestic.
Let's call the resulting object, Object C. It is my understanding that the rest mass of this object is 3 kg. Total rest mass of system = 3 kg.
So rest mass of A & B seperate = 2 kg. Rest mass of A+B = 3 kg. Is this correct?
A simple Duh, Yes of Course will suffice.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct26-09, 09:58 AM   #2
Yes, it is correct because you added 1 kg of kinetic energy.
P.S. It is not a conservation of mass but conversation of mass.
Oct26-09, 10:00 AM   #3
Quote by curiousphoton View Post
Simple question:
How do they accelerate? Do you put energy from outside into the system?
You mean the relativistic mass?
So the energy you put in for acceleration is converted to thermic energy.
Rest mass of A+B+thermic energy = 3 kg
Oct26-09, 02:45 PM   #4
Simple question:
Said in this way, it's already wrong, because the objects can move with respect the system's centre of mass. If that is the case, Total Rest Mass of system > 2 kg.
Better if you don't speak of relativistic mass, but of total energy.
Yes, *if* the system doesn't radiate away some energy because of the collision, in other terms, it's correct if you measure the system's rest mass before it radiates away any form of energy.
Oct26-09, 05:22 PM   #5
Quote by lightarrow View Post
Since we are looking at the objects at rest in this 'rest frame', and each object has a rest mass of 1 kg, why would the system's mass be greater than 2 kg?
Oct26-09, 08:20 PM   #6
Recognitions:
Retired Staff Staff Emeritus
Simple question:
It sounds to me like you've got the idea basically right, though your wording is rather awkward in a few spots.
Since rest masses don't add, people don't generally talk about "total rest mass", for instance. And "relative mass" doesn't make much sense, I assume this is a typo for "relativistic mass".
Let me write what I think you're trying to say in a totally different manner. If this isn't equivalent, but more detailed, than what you meant to write, then it's possible that there is still some communication problem ....
In computing the mass (i.e the rest mass, or invariant mass) of a system of many particles, we do not simply add together the masses of the component parts. Rather, we go to the definition of mass, which is m = sqrt(E^2/c^2 - p^2/c^4), where E is the total energy of the system, and p is its momentum. Thus one way of computing the mass of a system is to compute its total energy E in a frame in which the total momentum is zero - and then divide by c^2.
It is important that said multi-particle system be a "closed system" if we wish the mass that we compute in this manner to be independent of the observer.
Oct26-09, 10:35 PM   #7
Mentor
This is simply due to basic Minkowski geometry, the Euclidean analog is the triangle inequality.
Euclid: the length of the sum of two vectors is less than or equal to the sum of the lengths of the two vectors.
Minkowski: the mass (the invariant length of an energy-momentum four-vector) of the sum of two particles is greater than or equal to the sum of the masses of the two particles.
Each statement is a basic geometric fact that follows directly from the respective definitions of length.
Oct27-09, 11:34 AM   #8
Quote by DaleSpam View Post
Yes, I get that. Notice you said for Minowski: greater than OR equal to.
In this case, why would it not be EQUAL TO the mass of Object A and Object B. They are at rest in their rest frame.
Oct27-09, 04:13 PM   #9
Mentor
There is no inertial reference frame where both object A and B are at rest.
In Euclidean geometry the length of the sum of two vectors is less than or equal to the sum of the lengths of the two vectors, with equality only in the special case that the vectors are parallel.
In Minkowski geometry the "length" of the sum of two four-vectors is greater than or equal to the sum of the "lengths" of the two four-vectors, with equality only in the special case that the four-vectors are parallel. This special case implies that the objects are at rest wrt each other, i.e. that there exists some intertial frame where they are both at rest.
Oct27-09, 06:19 PM   #10
I'm sitting at my desk with Object A (Pen) and Object B (Pen #2) in front of me. My two pens and are at rest. Since you are saying there is no RF where both A & B are at rest, which one is moving, A or B?
Oct27-09, 07:56 PM   #11
Mentor
Huh? This conflicts with your previous description:
For the original description there is no reference frame where they are both at rest.
As I said in my previous post in the special case that the objects are at rest wrt each other then their energy-momentum four-vectors are parallel and the mass of the sum is equal to the sum of the masses. That special case obviously applies to your altered description.
Thread Closed
Thread Tools
Similar Threads for: Conservation of Mass
Thread Forum Replies
Conservation of Mass? General Physics 8
conservation of mass Biology, Chemistry & Other Homework 0
Conservation of mass Introductory Physics Homework 2
conservation of mass Classical Physics 7
