How many times as high to achieve twice speed
  • Thread starter Thread starter fattydq
    Speed
The problem involves a block sliding down a frictionless ramp, initially at rest, and aims to determine the height required to achieve a speed of twice the initial speed at the bottom of the ramp. The subject area pertains to the conservation of energy principles.
  • Participants discuss the conservation of energy equation, questioning how to relate height and velocity. There is confusion about the relationship between the height needed for different speeds and how to derive the necessary height for achieving double the speed.
Some participants have provided insights into the conservation of energy, while others express confusion regarding the calculations and relationships between height and speed. There is an acknowledgment of a potential answer, but uncertainty remains about the reasoning leading to the conclusion of needing four times the height.
Participants are grappling with the implications of the conservation of energy equation and its application to the problem, indicating a need for further exploration of the underlying concepts.
fattydq
A block initially at rest is allowed to slide down a frictionless ramp and attains a speed of v at the bottom. In order to achieve a speed of 2v instead at the bottom, how many times as high must the new ramp be?
What laws does this pertain to? I don't really know where to start.
It pertains to the conservation of energy.
mgh = 1/2*m*v^2.
mgh = 1/2*m*v^2.
But I don't understand...velocity is only on one side of that equation. So how would you work it out for this problem?
Exactly! What you have is the height of an object as a function of it's speed at the end. So if you know you must be a height, h, to achieve a velocity v, what must h be in order to achieve 2v?
2h, but it says the answer is 4 times as high...that's what's confusing me...I don't know how to reach this final answer of 4.
Nevermind, haha, I got it. Thanks a lot! Sorry for being a bit slow on the uptake : P
  • · Replies 32 ·
