Fourier Frequency Identification
The discussion focuses on using Fourier transforms to identify frequencies in complex waveforms for a high school physics demonstration. The original poster, Aaron, seeks assistance in interpreting the complex numbers generated by Mathematica's Fourier transform of a waveform created from a combination of sine functions. A suggestion is made to start with simpler trial functions, like sin(2πt) and a constant function, to better understand the relationship between frequency, amplitude, and the Fourier output. This foundational approach is recommended before progressing to more complex signals. Understanding these basics will help clarify the frequency information derived from the Fourier transform.
AaronMartin
I am a high school physics teacher and was thinking of demonstrating to students how frequencies of complex waveforms such as notes of instruments can be identified using a Fourier transform.
I haven't done Fourier transforms for a while and was quickly re-reading about them earlier this evening.
Essentially what I was after is given some data (collected using a data logger and microphone etc) or as an example a series of points generated from t=0 to t=10 in steps of 0.1 of 2 Sin[x + 1] + 2 Sin[3 x] + 2 Sin[4.6 x + 3]. Plotting this in Mathematica gives me a nice looking waveform.
If I then do a Fourier transform on the data produced using Fourier[data], Mathematica produces a Table of complex numbers.
Can someone please help me take these complex numbers and transform them into frequency information?
I attempted to do something like ListLinePlot[Abs[Fourier[data]], PlotRange -> All] but it produced a strange looking Plot which was nothing like I was expecting.
Thanks
Aaron
I recommend using some simple trial functions, and seeing what you get for a spectrum. Something like sin(2πt), which has a frequency of 1 Hz (for t measured in seconds). See where the non-zero number(s) is/are in the spectrum; this corresponds to an amplitude of 1 at a frequency of 1 Hz.
Also try the function f(t)=1, to see how a 0-Hz (DC) signal is transformed. Keep things simple until you understand how the frequency and amplitude is related to the output. Then you can put more complicated signals in and know what the output signifies.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
