Kenetric Energys, verolcity and mass of a falling object?
In summary: For part iii, think about how much time it takes for the ball to go up and come back down. It will take the same amount of time for each bounce, so the time will be 2t, where t is the time found in part i. Now, to find the formula for the time of the nth bounce, you can use the geometric series formula, Sn = a(1-r^n)/(1-r), where a is the initial height and r is the ratio of the height for each bounce. In this case, a = 10 and r = 0.8. Plug these values in and solve for n. The ball will come to rest when the height is 0. This will occur after an infinite number
stephanna
At t = 0 a rubber ball of mass m is dropped from a height of 10 m.
(i) When does it reach the ground? How fast is it moving when it hits the ground?
Each time it bounces, the ball looses 20% of its energy.
(ii) Calculate the height it reaches on the 1st bounce, and the time at which it hits the
ground for the second time and for the third time.
(iii) Find a formula for the time of the nth bounce. When does the ball come to rest?
[Hint: Look carefully at the times between bounces. You may use any formulae you know
from basic mechanics. The acceleration due to gravity is g = 9:81 m s^-2.]
2. Homework Equations
K.E. =1/2 * MV^2 Where M=mass V= Verlocity G=Gravity H=HEIGHT T=Time
P.E. =MGH
SO ...GH=1/2 * V^2 ...M is canceled from each side
V=H/T and V=(2*G*H)^-1/2 so both equations equal each other hence
T=H/(2*G*H)^-1/2
H=(1/2 * V^2)/G
3. The Attempt at a Solution
PART i)
GH=1/2 * V^2... T=H/(2*G*H)^-1/2
10/(2*10*9.81)^-1/2= 0.713921561 SECONDS
V=H/T 10/0.713921561 ms^-1 = 14.00714105
ii)
K.E. =1/2 * MV^2
1/2 * m *14.007^2 = 98.098MJ M is still in the equation as the mass is unknown
20% of the energy is now taken off
98.098MJ - ((98.098MJ/100)*20)= 78.4784MJ
V^2=(2*K.E.)/M
(78.4784MJ* 2)/M=156.9568
H=(1/2 * V^2)/G
H=(1/2*156.9568)/9.81= 8m Height at first bounce
Here is where i had the trouble
Im tring to find the time of the 2nd bounce but it works out smaller that the 1st bounce
78.4784MJ-((78.4784MJ/100)*20)= 62.7827MJ
V^2=(2*K.E.)/M
(62.7827MJ*2)/M= 125.56544
H=(1/2 * V^2)/G
H=(1/2*125.56544)/9.81= 6.3998m
T=H/(2*G*H)^-1/2 OR T= H/V 0.571125223
T=6.3998m/(2*9.81*6.3998)^-1/2 =0.571125223 seconds this value is smaller than the first value
For Part i, use the equation y = (1/2)gt^2, where y is the height and t is the time. Solve for t. You should get 1.43 seconds. To find out how fast it's moving, use the equation v = sqrt(2gh), where v is the speed and h is the height. You should get 14 meters per second.
For part ii, if it loses 20% of its energy on the first bounce, that means it still has 80% of it left. From the gravitational potential energy equation, U = mgh, you know that the new potential energy will be 0.8*U, and from there you can figure out the height. It should be 8 meters after the first bounce. Knowing this technique and the given hint, you can figure out the rest.
iii)
T=H/(2*G*H)^-1/2
T=H/(2*9.81*H)^-1/2
T=((2*H)^1/2)/(2*9.81)^1/2
T=((2*H)^1/2)/(4.417))
T=H^1/2/4.417
Now we know that the height decreases by 20% each time
So the formula for the height is H=(0.8)^n * 10 where n is the number of bounces
So the formula for the time of the nth bounce is:
T=((2*(0.8)^n * 10)^1/2)/4.417
T=((1.6*(0.8)^n)^1/2)/4.417
T=(1.26*(0.8)^n)^1/2
The ball will come to rest when its height is 0, so:
(0.8)^n * 10 = 0
(0.8)^n = 0
n=0
Therefore, the ball will come to rest after the 0th bounce, which is when it is dropped from the initial height of 10m.
1. What is the relationship between kinetic energy and the velocity of a falling object?
The kinetic energy of a falling object is directly proportional to its velocity. This means that as the velocity of the object increases, its kinetic energy also increases. This relationship is described by the formula KE = 1/2mv^2, where KE is kinetic energy, m is the mass of the object, and v is the velocity.
2. How does the mass of a falling object affect its kinetic energy?
The mass of a falling object also has a direct relationship with its kinetic energy. As the mass of the object increases, its kinetic energy also increases. This is because the object has more mass to accelerate as it falls, resulting in a higher velocity and therefore, a higher kinetic energy.
3. What is the unit of measurement for kinetic energy?
Kinetic energy is measured in joules (J), which is the standard unit for all forms of energy. 1 joule is equal to 1 kilogram-meter squared per second squared (kg•m^2/s^2).
4. How is the velocity of a falling object affected by air resistance?
Air resistance, also known as drag, is a force that opposes the motion of a falling object. As a result, it decreases the object's velocity and therefore, its kinetic energy. The larger the surface area of the object, the higher the air resistance and the greater the decrease in velocity.
5. Can the kinetic energy of a falling object ever be greater than its potential energy?
Yes, the kinetic energy of a falling object can be greater than its potential energy. This occurs when the object is in free fall, meaning there is no air resistance acting upon it. In this case, all of the object's potential energy is converted into kinetic energy as it falls, resulting in a greater kinetic energy than potential energy.
