Entropy & Energy: Why Do Things Move Away from High PE?
  • Thread starter Thread starter A.I.
    Energy Entropy
Things move away from high potential energy (PE) states toward high kinetic energy (KE) states to maximize entropy, as this transition is statistically more likely. The discussion highlights that energy distribution in a system tends to equalize among available degrees of freedom, leading to a preference for states with higher KE. As objects like a rolling ball convert PE to KE, they also dissipate energy as heat, further promoting entropy. The relationship between energy states and entropy is emphasized, suggesting that kinetic energy allows for greater randomness and energy distribution. Overall, the movement toward higher KE states is fundamentally linked to the drive for increased entropy in physical systems.
A.I.
Hello all. I'm not... really sure if this is the best place to post this question, so I'm open to any and all recommendations.
My question is: Why do things move away from high potential energy states and toward high kinetic energy states?
My thoughts: I was thinking about entropy recently, and if I remember correctly, things move from an area of high concentration to an area of lower concentration because that's the statistically most likely thing to happen. I was wondering if there was something similar going on with energy and motion. Do things behave this way because it is most likely?
Particularly I thought about how, in quantum physics, a quantum spring is most likely to be found at a position of high kinetic energy, as opposed to the classical spring which tends to spend most of its time in a high PE state.
Science news on Phys.org
Yep! I think so. Energy and entropy are very much related.
Things move away from high potential energy because of entropy...or more specifically, in order to maximize entropy. (Note: It also moves away from high kinetic energy states for that reason). And yeah, the reason it does so is because it's more statistically likely to be in that state.
Where is the energy in an object when it's not stored solely as potential energy?
Well, as a ball rolls down an incline for example, some of that energy stored in the object gets transferred to kinetic energy, or dissipated as thermal energy (heat)...distributing its energy so it's not concentrated.
Basically, if you look at the whole system microscopically, the total energy of a system would be equally split among its available 'degrees of freedom'. If you were to add more 'degrees of freedom' to the system, some of the energy in that system will spread over to that new state.
...so it is like things moving from higher concentration to lower concentration.
Edit: Oh, I misread your post.
I think this is right. Kinetic energy offers more possibilities to randomize energy. That's why it's favoured for increasing entropy.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
