Normal Force and Acceleration down the slope
The discussion focuses on the calculations of normal force and acceleration down an inclined plane in physics. The correct equation for normal force is derived as N = mg cos θ, where θ is the angle of inclination. For acceleration down the slope in a frictionless scenario, the formula a = g sin θ is used, emphasizing that the angle θ must be the angle of the incline, not the angle between the horizontal and the incline. The importance of drawing a force triangle to visualize these forces is highlighted as a key method for solving these problems.
  • Understanding of Newton's laws of motion
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of inclined plane physics
  • Ability to draw and interpret force diagrams
  • Study the derivation of normal force equations in inclined planes
  • Learn about force triangles and their applications in physics problems
  • Explore the effects of friction on inclined planes
  • Investigate the role of gravitational acceleration in various contexts
Students studying physics, particularly those focusing on mechanics and inclined plane problems, as well as educators seeking to clarify concepts related to normal force and acceleration.
lazyguy91
2. Homework Equations + questions
1) Normal Force
when considering mg as the vertical force,
mg = N cos θ
however, when considering N as the vertical force,
N = mg cos θ
note: θ is the same due to opposite angle
which equation is correct?
2) Acceleration down the slope due to gravity (frictionless)
a = g sin θ
why can't I use the originally given θ?
e.g. sin θ = g/a
a = g/sin θ
why must I use the derived θ instead of the one between the horizontal and the inclined place?
where are my mistakes? Please reply as soon as possible. Thanks
I don't know what your trying to do with all those equations and such, just try to understand the normal force.
The normal force is always going to be perpendicular to the plane on which the object lies. (Your drawing depicts this accurately)
We know that since its on an inclined plane its not going to simply just be N = mg(flat plane), its going to be some variation of that because of the angle of the plane. So how do we figure this out?
Well just simply draw a force triangle and solve it. You're going to have mg going straight down as the hypotenuse and the other two sides will be determined based on the angle of your plane. ( mgcos(theta) and mgsin(theta) ) [ You should find that mgcos(theta) is in the opposite direction of the normal force ]
As for part 2), you can also answer this once you've drawn your force triangle, mgsin(theta) should be acting parallel to the plane (depending on how you've defined your x and y axis).
  • · Replies 29 ·
  • · Replies 26 ·
