Incomprehensible part in Griffiths' text
  • Thread starter Thread starter WiFO215
    Griffiths Text
The discussion centers on the self-energy of charge configurations and the implications of infinite energy required to construct a point charge, as noted by Griffiths. It highlights the confusion surrounding the concept of setting the zero of potential at infinity, which leads to infinite potentials and energy issues in classical electromagnetism. The conversation suggests that redefining the zero potential at the location of the point charge could resolve the infinity problem. Additionally, it touches on the behavior of electric fields from infinite charge distributions and how charge density affects field strength as dimensions increase. The key takeaway is the importance of carefully choosing the reference point for potential in electromagnetic theory.
WiFO215
After deriving the self energy, or the energy to construct a charge configuration\frac{\int_{V} \epsilon E^{2}dV} {2}(where V is the volume over which the E-field of the configuration extends.)
Griffiths goes on to say that the energy required to construct a point charge using the above formula would be infinity. With this statement, I can agree. But then he also adds that this is a big problem with classical EM theory. I cannot comprehend that. I don't quite see the problem.
Remember when we were dealing with the field of an infinite sheet? The field turns out to be a constant,
\frac{\sigma}{2 \epsilon}
where \sigma happens to be uniform charge density over the infinite sheet. In that problem, when we set the zero of the potential at infinity, the problem got very messy. Potentials would always shoot to infinity. That problem was crucial (at least to me) in showing that one ought to be careful in setting the zero of the potential.
If we carry over what we've learnt, then the "problem" of infinities of a point charge disappear. In deriving the above formula for energy of a point charge, he sets the zero at infinity. Why not just set the zero AT the point charge in this problem? Wouldn't that solve the problem?
Please take a look at what is set to zero. Is it the field or is it the potential? What difference does that make? <--- There's a hint in my wording.
Also put a finite charge q on a finite sheet of area A. As the area of the sheet increases, the charge density decreases as σ' = Aσ/A'. So the field drops off with length squared as dimensions increase to ∞.
Bob S
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
