Time of maximum displacement in simple harmonic motion?
The discussion revolves around a problem in simple harmonic motion, specifically focusing on determining the time at which the displacement of an object first reaches its maximum based on the given equation of motion.
  • Participants explore the equation of motion and its components, questioning the significance of the phase constant and the amplitude. There are discussions about the conditions for maximum displacement and the relationship between displacement and velocity in simple harmonic motion.
Several participants have offered insights into the problem, including the need to find when the sine function reaches its maximum value. There is an exploration of different methods to approach the problem, including the use of derivatives to find when velocity equals zero. However, no consensus has been reached on a specific method or solution.
Participants note that the original poster has provided limited information and express confusion regarding the phase constant and its implications for the motion described. There is an emphasis on understanding the relationship between the position and velocity equations in simple harmonic motion.
liltiga
I am completely and totally lost...
The motion of an object is simple harmonic with equation of motion x = (27.1 m) sin(16.0 t /s + 0.7). At what time after t = 0 will the displacement reach its first maximum (where velocity equals zero)?
x = Asin(wt)
x = Asin(wt)
x = Asin(wt +...) The 0.7 means something in this equation... And do you know what the maximum displacement is from the equibrium position by just looking at the equation you were given?
Another way of looking at it... Do you have an equation for the velocity at any given time?
oh, sorry it's x=Asin(wt+f), I think.
No, it didn't give me the displacement from equilibrium, I gave all that I had for it.
Another way of asking the same question is the equation consists of two parts:
A, the amplitude (maximal displacement) and a time varying function given by sin (some function).
Since A = 32 = constant, the maximal value will occur when sin (some function) = 1. This of course will happen over and over as sin varies between -1 and 1. But it is asking for the value of t when this first occurs. So what you need to solve for is when the argument of the sin is equal to pi/2 radians(90 degrees). In other words (16t + 0.7) = pi/2.
The other approach using knowledge of min, max and first derivatives is to take the derivative of the function 27.1 sin (16t+0.7). and solve for when that will be zero.
Well actually its A, as long as the entire part sin(wt + f) = 1.
But because your mass or whatever is at a starting position of f, then the mass is going to move in some amount of time to get to A. f is some starting position, the position at t = 0s.
So I have given you one hint with the first equation on how to find the time where sin() = 1 meaning the object would be at its maximum displacement from equilibrium.
Another way is to get the velocity equation with respect to time. You have the position equation with respect to time. So if you know the velocity equation, you can set V(t) = 0 m/s or w(t) = 0 rad/s and get the time where the object that is oscillating is at its maximum displacement. Have you been given the velocity equation for SHM, or have you been shown how to take the derivative of the position equation with respect to time to get the velocity function with respect to time for SHm?
Whoops I see the other poster has said somewhat the same thing.
  • · Replies 51 ·
