What Is the Ferry's Velocity Relative to the Water?
The discussion centers on calculating the ferry's velocity relative to the water using vector components. The passenger's velocity is given as 1.90 m/s north relative to the ferry and 4.5 m/s at an angle of 33.0° west of north relative to the water. The correct approach involves breaking down the velocities into x (east-west) and y (north-south) components, leading to the ferry's velocity being calculated as approximately 2.45 m/s in the x-direction and -1.87 m/s in the y-direction. The final magnitude and direction of the ferry's velocity relative to the water is determined using the vector addition formula.
  • Understanding of vector decomposition in physics
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of the vector addition formula (Vfw = Vfp + Vwp)
  • Ability to calculate magnitudes and angles using the Pythagorean theorem and arctangent
  • Study vector decomposition techniques in physics
  • Learn how to apply trigonometric functions in vector calculations
  • Explore the concept of relative velocity in different reference frames
  • Practice solving problems involving vector addition and subtraction
Students studying physics, particularly those focusing on mechanics and vector analysis, as well as educators looking for examples of relative motion problems.
planke
A passenger walks from one side of a ferry to the other as it approaches a dock. If the passenger's velocity is 1.90 m/s due north relative to the ferry, and 4.5 m/s at an angle of 33.0° west of north relative to the water, what are the direction and magnitude of the ferry's velocity relative to the water?
_____ degrees west of north
_____ m/s
Vfw = Vfp + Vwp
theta (angle) = tan-1 (Ay/Ax)
A (magnitude) = sqroot (Ax^2 + Ay^2)
Vfw = 1.9 ^y + (-4.5) cos (33) ^x
theta = tan-1 (1.9 / -4.5 cost (33)) = -26.7 degrees
magnitude = sqroot (1.9^2 + (-4.5 cos (33))^2) = 4.2 m/s
I don't understand what I did wrong.
I think you just found a few equations and are jamming in the numbers you found in the question in hope of getting the right answer. I'm not sure where you made your mistake because the proper way to do the question into understand what is really happening. I'm not sure what level of physics you are doing right now but this is how I would solve the problem:
Break up into x and y components (I would suggest x being the east and west direction and y being the north and south direction).
y components: (note that whether to use cos and sin for this part can most easily be found by drawing out the vectors)
Vpw = Vfw + Vpf
4.5 cos33 = Vfw + 1.9
=> Vfw = -1.87
x components:
Vpw = Vfw + Vpf
4.5sin33 = Vfw + 0
=> Vfw = 2.45
The magnetude and direction of the vector can be found using the formulas that you posted
planke said:
Vfw = Vfp + Vwp
That should be:
Vfw + Vwp = Vfp
Don't forget that Vwp has both x and y components. Note that the angle is given with respect to north (the y-axis, not the x-axis), so you'll need to redo the x-component.
