Effect of oscillating magnetic field on diamagnetic water
The discussion centers on the effects of an oscillating magnetic field on diamagnetic water, specifically when a large electromagnet is placed above it. The inquiry explores whether oscillating the magnet at the resonant frequency of water would create waves due to constructive interference. A participant suggests that microwave frequencies are necessary for this experiment, likening it to the operation of a microwave oven. The original poster also questions how the presence of saltwater would alter the effects observed. Overall, the conversation highlights the complexities of resonant frequencies and their impact on water's behavior in a magnetic field.
taylaron
I’m interested in the natural phenomenon of diamagnetism. I understand the general concept behind the magnetic interactions, but I am curious about the results of the following experiment:
What happens when one places a large oscillating electromagnet (possibly superconducting) directly above a body of water with the axis of electromagnet normal to the surface of the water?
Because the diamagnetic properties of water, it sets up a magnetic field opposed to that of the coil. Once the coil is oscillating at the resonant frequency of the water, does the magnet effectively produce waves in the body of water?
I’m relating this experiment to that of the effect of resonant frequencies on buildings. I expect the amplitude of the waves on the water to increase due to constructive interference.
I recognize the maximum frequency is limited by the impedance of the coil.
Is the effect any different with a voltage applied to saltwater?
I’ve been unable to find any documentation of similar experiments; any help would be appreciated.
Regards,
Tay
Right idea, wrong range of frequencies. You need microwave frequencies, because you are attempting to re-invent the microwave oven.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
