What Does Tension of Our Universe Mean?
  • Context: Graduate
  • Thread starter Thread starter alejandrito29
    Mean Tension Universe
The discussion revolves around the concept of brane tension in the context of a brane universe, specifically exploring its implications when the tension is positive, negative, or zero. Participants examine the relationship between brane tension and cosmological constants, as well as the effects on the universe's expansion or contraction.
  • Some participants propose that brane tension can be interpreted as a cosmological constant.
  • One participant questions the meaning of brane tension (T) and its relationship to the cosmological constant (Λ), suggesting that if T is positive, the universe may be expanding, and if negative, it may be contracting.
  • Another participant argues that the value of the effective cosmological constant alone does not determine whether the universe is contracting, static, or expanding, emphasizing the importance of initial conditions and other field content.
  • There is a mention of the effective 4D brane cosmology being influenced by both the higher-dimensional bulk cosmological constant and the brane tension.
Participants express differing views on the implications of brane tension for the universe's dynamics, and the discussion remains unresolved regarding the definitive effects of positive, negative, or zero tension.
Limitations include the dependence on initial conditions and the need for further mathematical details to fully understand the implications of brane tension in cosmological models.
alejandrito29
what means when the tension of our brane (universe-(t,x,y,z)) is:
- positive
- negative
- zero??
Assuming that ours is a brane universe, brane tension will be interpreted by us as cosmological constant.
Torquil
Torquil
i don't understand
the field equation is, for example:
[tex](G_{mn}+\Lambda g_{mn})=\frac{\sqrt{h}}{\sqrt{g}}h_{uv}T\delta(w-w_0)[/tex]
but , i think that [tex]\Lambda[/tex] is a cosmological constant.
¿what mean the tension [tex]T[/tex]?
If [tex]T[/tex] does the same function that [tex]Lambda[/tex] then:
¿if T is positive then our universe is expanding?
¿if T is negative then our universe is contracting?
¿what abaut if T=0?
You cannot say from the value of the lower dimensional effective cosmological constant alone if our 3D space is contracting, static or expanding with time. That would depend on initial conditions, and other field content.
The effective 4D brane cosmology will be described as having a cosmological constant which is contributed to by both the higher dimensional bulk cosmological constant, and the brane tension.
Here is a reference on brane cosmology, where you can find mathematical details, and other references:
http://arxiv.org/abs/hep-th/0209261/
Torquil
