Affects of Adding Water to Cobalt Chloride Equilibrium
  • Thread starter Thread starter tkahn6
    Equilibrium Water
The discussion focuses on the effects of adding water to the cobalt chloride equilibrium reaction: Co(H2O)62+ (aq) + 4Cl- (aq) <=> CoCl42- (aq) + 6H2O (l). It emphasizes that while water is a liquid and does not affect the equilibrium concentration, its addition dilutes the concentrations of the reactants and products. This dilution leads to a shift in equilibrium towards the left, favoring the formation of Co(H2O)62+ ions. The discussion clarifies that the concentration of water is conventionally considered constant at 1M in equilibrium calculations.
  • Understanding of Le Chatelier's Principle
  • Knowledge of chemical equilibrium concepts
  • Familiarity with cobalt chloride and its aqueous reactions
  • Basic grasp of molarity and concentration in solutions
  • Study Le Chatelier's Principle in detail
  • Research the concept of dilution effects on chemical equilibria
  • Explore the properties of cobalt complexes in aqueous solutions
  • Learn about equilibrium constants and their calculations
Chemistry students, educators, and anyone interested in understanding chemical equilibria and the effects of concentration changes on reaction dynamics.
tkahn6
Effects of Adding Water to Cobalt Chloride Equilibrium
[tex]Co(H_{2}O)_{6} ^{2+} (aq) + 4Cl^{-} (aq) \Leftrightarrow CoCl_{4} ^{2-} (aq) + 6H_{2}O (l)[/tex]
[tex]Pink \Leftrightarrow Blue[/tex]
We're learning about Le Chatelier's Principal.
My question is:
Why does the reaction shift the left when adding [tex]H_{2}O[/tex]?
My first thought was that stress is being added to the right side of the equation and so equilibrium shifts left. This is incorrect because [tex]H_{2}O[/tex] is a liquid and therefore is not part of the equilibrium reaction (it has no concentration).
The addition of water does however dilute both sides of the equation. This is the explanation my teacher gave but going back over it, diluting the concentrations of the products and reactants would give you a larger [tex]K_{c}[/tex] which would shift it to the right.
Thank you.
At the molecular scale, the individual reactions don't stop just because the reaction is in equilibrium. They continue, but the rate going forward is the same as the rate going in reverse.
In other words, [itex]\mathrm{Co(H_2O)_6^{2+}}[/itex] ions get together and react with four chlorine ions each at the same rate that cobalt chloride ions get together and react with six water molecules.
If you had a lower [itex]\mathrm{Co(H_2O)_6^{2+}}[/itex] concentration, for example, the forward reaction would be less likely to occur because it would be harder to find a [itex]\mathrm{Co(H_2O)_6^{2+}}[/itex] ion to react.
So what happens when water is added?
Your second thoughts
are better than your first or third. Pedantically it is hardly correct to say water has no concentration, rather it has a constant concentration which essentially the rection does not change, therefore you can ignore water in considering the equilibrium. This is often expressed 'the concentration of water is conventionally set as 1M'
If you just consider the equilibrium to be
[tex]Co ^{2+} + 4Cl^{-} \Leftrightarrow CoCl_{4} ^{2-} (l)[/tex]
the problem and answer will become clearer to you.
