Thread Closed
Rotation of a planet, kinetic energy
Share Thread Thread Tools
Mar5-10, 04:20 PM   #1
Calculate the ratio between the kinetic energy of rotation of a planet (mass=4.30E+24 kg, radius=7.60E+6 m) to the kinetic energy of its center of mass orbiting around its sun at a distance of 1.20E+12 m. Like the Earth, it has a day lasting 24 hours and a year lasting 365.25 days.
2. Relevant equations
KErot= (1/2)Iw^2 and I believe KE=(1/2)mv^2
3. The attempt at a solution
For the KErot:
KErot= (1/2)((2/5)(4.3E24kg)(7.6E6m)(2pi/(24hr*60min*60sec))^2
and I got 2.62698301E29 J
for the other one:
KE=(1/2)(4.30E24kg)(2pi*1.2E12m/(365.25days*24hrs*60min*60sec))
and got 1.22730571E35 J
I devided KE by KErot and got 467192 for the ratio. but it's wrong and I know I'm doing something wrong but can't figure it out. any help will be great!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar5-10, 04:50 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Dotty21690! Welcome to PF!
(have an omega: ω and a pi: π and try using the X2 tag just above the Reply box )
Quote by Dotty21690 View Post
For the KErot:
for the other one:
Did you remember to square the radius in both cases?
Mar5-10, 05:08 PM   #3
Why would you square the radius in the second part? because isn't the V=Rw?? so the radius wouldn't be squared?
Mar5-10, 05:13 PM   #4
Recognitions:
It's still mv2, which is mR2w2.
Mar5-10, 05:16 PM   #5
i'm still getting the wrong answer and I don't know why.
Mar5-10, 05:25 PM   #6
am I using the wrong equation to find the kinetic energy of the center of mass for the orbit??
Mar5-10, 05:34 PM   #7
Recognitions:
You should be using 1/2 mv2 which is the same as 1/2 m (2πr/T)2
Mar5-10, 05:48 PM   #8
so when I plug in my information it will look like this?:
(1/2)(4.3E24kg)((2π*1.2E12m)/31557600sec)^2)
I get 1.22730571E35. but when I do the ratio, I'm getting the answer wrong.
Mar6-10, 03:53 AM   #9
Recognitions:
Hi Dotty21690!
(please use the X2 tag just above the Reply box )
Show us your full calculations (and cancel out the common factors before you start).
Mar6-10, 10:26 AM   #10
well I showed the work earlier to get the answers for the KErot and KE, then I divided. I'll post it again though:
For the KErot:
for the other one:
then I divided 1.22730571E35 J/2.62698301E29 J and got 467192.1. I don't even know if I am doing the problem right.
Mar6-10, 11:05 AM   #11
turns out the answer was 2.140*10-6, which I had got at one time, but it said it was wrong :( but I don't know how to get that answer again. so can someone help me with this one?
Mar6-10, 04:10 PM   #12
Recognitions:
I think you divided your ratio the wrong way. After all, the answer's power is suspiciously close to your answer's power.
Mar6-10, 04:35 PM   #13
turns out I did divide the wrong way!! but I wonder why I was told the answer was wrong when I did put in 2.140*10-6, hmm. But thanks guys!!
Thread Closed
Thread Tools
Similar Threads for: Rotation of a planet, kinetic energy
Thread Forum Replies
Kinetic Energy of a Planet Astrophysics 5
rotation kinetic energy/linear velocity Introductory Physics Homework 4
Rotation Problem/Total Kinetic Energy Introductory Physics Homework 1
Planet/moon rotation Astrophysics 1
Can planet rotation slow down? Earth 16
