| New Reply |
Mechanics Problem HELP! |
Share Thread |
| Feb27-11, 11:49 AM | #86 |
| Feb27-11, 12:31 PM | #87 |
Shear forces at both ends then, lhs acting downwards at 64.5sin15 and rhs acting upwards at 64.5sin15?
So the axial force of 64.5cos15 is what equals the ground reaction force to make the sum of Fx=0? When drawing the shear and moment diagrams, how is the axial force incorporated? What effect does it have? |
| Feb27-11, 03:10 PM | #88 |
| Feb27-11, 03:21 PM | #89 |
Brill, thank you!!
My shear force diagram is looking like a vertical line down to -16.69N, horizontal line straight along to the rhs then back up to 0? As for the BM diagram, I'm not so sure, but it has to go vertically staight down to -68.1Nm and then up to 128.4Nm at the rhs? Is this a curve crossing at the centre point of the 0 line, not a linear line? The induced stresses are a combination of which, sorry? The shear forces and the axial force? Although I know what the P/A +/- Mc/I means, how am I to apply this? How do you mean per? |
| Feb27-11, 09:22 PM | #90 |
| Feb28-11, 07:17 AM | #91 |
i am confused about the moment at the slanting bit... i have worked it out as 134 .. is that right
| Feb28-11, 08:35 AM | #92 |
Ok let's crank it out. P1 is (20)(2.15) = 43 and P2 is (20/2)(2.15) = 21.5, so the vert load is 64.5 N. The moment about the support is 43[(2.15/2) +.1 + 4 sin15] + 21.5[(2.15/3) + .1 + 4 sin15] = 134.9 N-m. Or, if you look at the moment at the support in the free body of the slanted member, it's 64.5(4)(sin15) + 68.1 = 134.9 N-m.....checks out OK.
| Feb28-11, 09:58 AM | #93 |
Using the bending equations, I have a value of approx 88Pa for the induced stresses.
Am I right in using the the biggest moment in the equation, which is at the ground? |
| Feb28-11, 10:42 AM | #94 |
Sorry, 44.24MPa
| Feb28-11, 11:27 AM | #95 |
| Mar1-11, 07:33 AM | #96 |
Hi, i am having the same trouble with this assignment, mainly drawing the free body diagram of each section. Not sure exactly whether to draw it as a full frame or two seperate parts.
thanks |
| Mar1-11, 09:30 AM | #97 |
| Mar1-11, 09:49 AM | #98 |
Thanks, so for the horizontal piece, when your working out the vertical forces, how do you know whether to use the 20Mn or the 40Mn? and does it only have 2 downward forces due to the billboard and one moment force due to the slanted piece?
Thank you |
| Mar1-11, 09:51 AM | #99 |
sorry i ment 20Nm and 40Nm
| Mar1-11, 12:24 PM | #100 |
| New Reply |
Similar discussions for: Mechanics Problem HELP!
| AP Mechanics Problem | Introductory Physics Homework | 1 | ||
| Mechanics problem | Introductory Physics Homework | 5 | ||
| Solid mechanics problem (pretty much a static problem) | Introductory Physics Homework | 1 | ||
| mechanics problem | Introductory Physics Homework | 1 | ||
| Mechanics problem | Introductory Physics Homework | 1 | ||
