What is the degrees of freedom of helium gas ?
Helium gas is monatomic, meaning it consists of single atoms rather than pairs, which classifies it as a noble gas. The degrees of freedom for monatomic gases like helium is 3, corresponding to the three translational motion axes. In contrast, diatomic gases have 5 degrees of freedom due to additional rotational motions. The periodic table can help identify whether an element is monatomic or diatomic, with helium being a clear example of a monatomic noble gas. Understanding these distinctions is crucial for studying gas behavior in thermodynamics.
thereddevils
what is the degrees of freedom of helium gas ?
shouldn't helium gas be diatomic ? If so , it will be 5 .
i have problems differentiating monoatomic and diatomic . Though its obvious that mono is one atom and diatomic is 2 atoms . Is it possible to know whether its mono or diatomic from the periodic table ?
Helium is monatomic and is called a "noble" gas for that reason. All gases in the same column below helium in the periodic table are noble gases.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
