Beekeeping & Gravitational Winds: Examining Feral Comb Alignment
  • Thread starter Thread starter Ian Rumsey
    Gravitational
The discussion explores the alignment of feral bee combs, specifically their East-West orientation, and the potential influences of aerodynamic properties, magnetic fields, and environmental factors. The scope includes theoretical considerations, biological implications, and potential experimental observations.
  • One participant notes that feral bee combs are oriented East-West and suggests that their aerodynamic shape may be influenced by environmental factors such as wind and magnetic fields.
  • Another participant proposes that the Coriolis effect and the sun's movement could also play a role in the orientation of the combs.
  • There is a suggestion that bees may possess a mapping ability that helps them orient themselves to find flowers, which could relate to their comb alignment.
  • A later reply mentions that while horizontal magnetic fields do not seem to affect orientation, vertical magnetic fields can change direction significantly, indicating a complex interaction.
  • One participant expresses a desire for input from an aerodynamic engineer regarding the comb's shape and its aerodynamic properties.
Participants express various hypotheses regarding the factors influencing comb alignment, but there is no consensus on which factors are most significant or how they interact. Multiple competing views remain, and the discussion is unresolved.
Some assumptions about the effects of magnetic fields and environmental influences on bee behavior are not fully explored. The discussion also highlights differing perspectives between entomologists and engineers regarding the interpretation of the data.
Beekeepers, biologists, engineers, and those interested in the intersection of biology and environmental science may find this discussion relevant.
Ian Rumsey
I am a beekeeper and study feral colonies of bees.
The natural comb that they build orientates itself in an East-West alignment.
The comb is aerodynamically shaped, the leading edge is vertical facing East and the trailing edge is angled at about 45 degrees and where it joins the roof there is a small indentation which may be caused by a vortex.
Such a shape would be ideal in water at say 10mph or air at 100 mph or something less dense at 1000 mph.
Would this resistance be caused by cutting the Earth's magnetic field at right angles, or is there a force produced by rotating objects like a gravitational wind being generated as magnetic fields are produced by rotating magnets.
Bees may have an awareness of something beyond our perception.
Gyroscopes and this Wind may have some connection.
Any advice or help would be appreciated.
I have a photo of this type of comb which has been scanned so I can send it to anybody that might be interested.
Biology news on Phys.org
My initial thoughts are as yours, - magnetic fields (a lot of rocks are seen to have macroscopic east-west grain patterns in them from alignment when they cooled) and wind, - the coriolis effect may be relevant here, - I believe British prevailing winds cause many coastal plants to orientate themselves such. My only other thought would be that the effect of the sun rising in the east and setting in the west could be a factor? Would definitely like to see the photo, can you post it somewhere?
Cheers
Might another option be for the bees' mapping ability? If they need to know where to go to get to the best flowers, they'd need to orient themselves properly.
I also think this topic would be better suited to biology, so I'm going to move it there.
There is a copy of this photo on http://www.bee-l.com/biobeefiles/ian/hp.htm
The subject itself seems to cover a wide range of options and I find it difficult to find the correct slot.
Magnetic fields horizontally applied do not appear to affect the orientation, but vertical magnetic fields change the direction through 90 degrees.
Entomologists and Engineers see things differently.
I only wished for a aerodynamic engineer to comment on the shape of the comb regarding its aerodynamic properties.
  • · Replies 40 ·
  • · Replies 21 ·
  • · Replies 44 ·
21K
  • · Replies 24 ·
