Meter Circuit: Calculating Scale Reading with and without Additional Resistor
  • Thread starter Thread starter thereddevils
    Circuit Meter
The discussion revolves around calculating the scale reading of a meter circuit when an additional 2000 ohm resistor is connected. Initially, the current without the resistor is calculated as 0.0005 A, leading to an ammeter reading of 12 based on a multiplication factor of 40600. However, the correct approach involves recognizing the total resistance in the circuit, which includes the additional resistor, resulting in a new current calculation of 0.0003 A. This leads to a revised scale reading, although there is confusion regarding the expected answer of 25. The conversation emphasizes the importance of accurately determining net resistance and current for proper scale reading calculations.
thereddevils
Meter in the circuit shown has a linear scale that has not been calibrated and the scale reading is 20 . When another resistor of resistance 2000 ohm is connected across XY . What is the scale reading of the meter
Without the 2000 ohm resistor , I= 1.5 /(2995 + 50) , I = 0.0005
the reading given by the ammeter is 40600 times of the actual current .
now with the resistor , I = 1.5/(2995 + 50+2000) , I = 0.0003
the reading by the ammater will be 0.0003 x 40600 = 12
but the answer given is 25
This is wrong. In the given circuit the total resistance is (2995+50 +2000)
Find the current I.
I = k*θ. where k is the constant of the meter and θ is the deflection in the mete.
When you connect another 2000 ohm resistance in parallel with 2000 ohm resistance in the circuit, what is net resistance in the circuit? Find the current and equate it to k*θ'. find θ'.
Find the current I.
got it ! Thanks !
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
