| Thread Closed |
Calculating water flow over a solar panel |
Share Thread | Thread Tools |
| Mar28-10, 05:07 AM | #1 |
Hi all, firstly i'm sorry because don't know which thread category should I ask from, but here goes:
I'm doing my final year project about cooling solar panel with water film.basically it's flowing water over the panels. how can I calculate the water flow? does this have got to do with the q= m.c.deltaP? c being the specific water heat capacity? |
| Mar28-10, 07:01 AM | #2 |
I think you need to elaborate the question. Is the answer as simple as finding the volume of water you have poured over the panel? re-word your question :)
| Mar28-10, 07:56 AM | #3 |
so what data should i need to know in order to get that water flowrate? |
| Mar28-10, 08:05 AM | #4 |
Mentor
You need to know the amount of heat being absorbed by the solar panel that you want to dissipate.
Also, I don't see anything in your description about removing the heat from the water - so the water is just going to keep getting warmer and warmer. |
| Mar28-10, 08:52 AM | #5 |
| Mar29-10, 10:49 AM | #6 |
| Mar29-10, 12:08 PM | #7 |
I assume you are trying to cool a photovoltaic panel to make it more efficient. If this is the case, there is a break point at which the cost of moving the water will exceed the benefit of cooling the panel. As an extreme example, 1000 gpm poured over a single panel will certainly cool the panel, but will require a high HP pump, large piping, a large tank to catch the water, but the TD of the entering to leaving water will be low. The cost of a system moving 1000 gpm over a single panel would not be recoverable by efficiency gain of the solar panel in a reasonable amount of time.
A better use of the recovered cooling water would be to heat another process, such as preheat domestic water before it goes to a water heater. Then calculate how many gallons per day could be preheated from say 50 deg F to 80 deg F. Then figure out how many gpm that requires and the temperature difference, account for evaporation, it will have to have a heat exchanger so there will be efficiency losses in that. |
| Mar29-10, 12:21 PM | #8 |
Mentor
Also, I don't think you want to flow the water "over" the solar panel. Why would you not want the sunlight to have to go through the water to get to the cells? How else could you route the water? Are there maybe other means of cooling the panels? Where are they mounted? What is the optimum operating temperature of the panels, and how does the efficiency vary about that temperature?
| Mar31-10, 06:58 AM | #9 |
I would also think that running water in a "non sealed" system over the front would lead to deposits being left on the solar panel, slowly decreasing its efficiency, too
I wound think more on the lines of a heat sink on the back to draw the heat away dr |
| Mar31-10, 09:09 AM | #10 |
If rainwater could be collected that is fairly soft and would leave fewer deposits. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculating water flow over a solar panel
| solar boat having solar panel power problem | General Engineering | 13 | ||
| 6V 300mA solar panel or 4v 430mA panel | Mechanical Engineering | 5 | ||
| "shower head" for feeding water onto a solar thermal panel | Engineering Systems & Design | 14 | ||
| Calculating the flow of water | General Physics | 0 | ||
| Calculating water flow | General Engineering | 2 | ||
