How Do You Solve for the Potential Outside a Dielectric Half-Space?
Einsteinium1
A point charge q is a distance d from a dielectric half-space (z < 0). We will
solve for the potential outside of the dielectric, in the region z > 0.
(a) Away from the point charge, what equation does V satisfy? Find the boundary conditions at the dielectric surface.
(b) Find an image charge in the dielectric slab that allows you to satisfy the
boundary conditions. What is the potential V outside the dielectric?
(Hint: as \epsilon -> \infty, you should recover the result for a charge next to an infinite conducting half-space.
I'm pretty lost with this question. Any hints starting the problem would be very helpful. Thank you.
(a) is pretty simple. In free space, what equation do you use for the potential?
You can get the BC's from Gauss's law and Faraday's law for the electric field. Then convert those to BC's for the potential.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
