Why is electricty conducted through salt water?
Electricity conducted through salt water involves the movement of ions, where negative chloride ions migrate toward the positive terminal and sodium ions toward the negative terminal. This movement occurs because it is energetically favorable for ions to remain ionized in water rather than forming neutral atoms. The polar nature of water stabilizes these ions, preventing them from deionizing through electron transfer. At the anode, the electric field from the battery causes chloride ions to lose electrons, while at the cathode, sodium ions gain electrons. This process illustrates the fundamental principles of electrochemistry in a saltwater solution.
sameeralord
Ok so when I pass electricty through salt water the negative ions move from highly negative area to positive area causing a current? My question is why do the move? Let's say there was Sodium and Chloride ions in water. Can't the chloride ion give an electron to sodium and make the whole solution deionized, why do they choose to move instead?
Thank you :smile:
Thank you :smile:
The simplest reason is that it takes *way* less energy to move ions around than to transfer electrons between oppositely charged ions. This is because many simple ions (like Na+ and Cl-) are stabilized by interactions with water, so they are "happier" (i.e. existing in a lower energy state) as ions than as neutral atoms in water.
If that happens, it indicates a chemical reaction. For every chemical reaction to happen, it requires appropriate environment i.e. pressure, temperature and other parameters. Now water being a polar solvent doesn't provide chloride ions appropriate environment to transfer their excess electrons to sodium ions. Instead they remain ionized in a polar solvent like water as the water provides that kind of environment to stay them ionized. After being ionized the anion chloride ions are attracted to the anode connected to the +ve terminal of the battery and cation sodium ions are attracted to the cathode connected to the -ve terminal of the external battery. Then each of them take and leave electrons in the cathode and anode.
Thanks for the great replies :smile: I have just one mini question left.
I can understand how reduction reaction can occur in the catode because they supply electrons at that end, but in the anode what make the ion lose its electrons thanks.
The event of losing electrons in anode can be interpreted in terms of the electric field set up by the external battery. As the battery exerts an electric force on the negatively charged chloride ion, its excess electron located loosely in its out most shell is attracted by the electric force . The electric force F= qE accelerates the excess electron of chloride ion to the direction of +ve terminal. Hence, chloride ion leaves electrons in anode.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
