Conducting Rod in Electric Field
The discussion revolves around the behavior of an uncharged metal rod placed in a uniform electric field, specifically whether a potential difference develops between its ends and how this potential difference relates to the external electric field.
  • One participant questions if a potential difference develops across the ends of the rod when placed in an electric field E.
  • Another participant suggests that the potential difference can be calculated using the integral of the electric field over the distance between the ends of the rod.
  • Some participants argue that any potential difference would be short-lived due to the rearrangement of charges within the conductor, leading to no potential drop across it.
  • However, one participant challenges this view, proposing that a potential difference will develop and persist within the conductor, resulting in an internal electric field that opposes the external field.
  • Another participant agrees that the electric field inside the conductor will be zero, implying that the potential difference calculated over the length of the conductor would also be zero.
Participants express differing views on whether a potential difference develops and persists within the conductor, leading to unresolved disagreement on this topic.
The discussion highlights the dependence on the definitions of potential difference and electric fields, as well as the assumptions regarding charge distribution in conductors under external electric fields.
Apteronotus
If an uncharged conductor, a metal rod say, is placed in a uniform electric field E, parallel to the field (see figure), does it develop a potential difference between its two ends?
If so, how is the potential difference related to the field E?
By the definition, the electric potential, as the energy required to bring a point charge from point B to point A, is given by the negative integral of E over the distance dr from B to A. That is,
[tex]\int^{B}_{A}Edr[/tex]
Just try to apply this on your case where A and B are different positions of the ends.
Well, if there is a potential difference, it will be very short lived. Since this is a conductor, the charge inside the conductor will re-arrange itself so that there is no potential drop across the conductor.
Yes I think you're right! And remember the concept of bound and free charges.
Actually, I'm not sure this is true. I've given the problem some thought since my original posting. I think a potential difference will in fact develop (and maintain) within the conductor. It's effect will be an electric field within such that the magnitude of the field will be equal to that of the imposed electric field (outside field) and will point in the opposite direction.
So the superposition of the two fields will be zero within the conductor.
Yes, the field will be zero within the conductor. So, if you do a line integral from one end to the other you will get zero for the potential difference.
  • · Replies 21 ·
