| Thread Closed |
[Thermo] Derivation of compressibility factor vs reduced pressure |
Share Thread |
| May4-10, 10:55 PM | #1 |
derivation of compressibility factor vs. reduced pressure I am supposed to derive the graph by solving equations ![]() 2. Relevant equations Van der Waals equation of state compressibility factor, Z = (Pv)/(RT) reduced pressure = P/critical pressure Z = f(Tr, Pr) 3. The attempt at a solution I sat for 12 hours attempting to find a solution but just spent time trying to understand what I was doing instead. Is there a way to get the graph mathematically without using any values for critical pressure or temperature? Thank you! 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| May5-10, 03:35 PM | #2 |
Compressibility charts are derived from experimental data from 10 gases such as propane, Nitrogen, Carbon Dioxide etc. Select a gas you have properties for such as propane. Tc propane is 370 K. Pc propane is 42.7 bar. Assume a constant temperature of let's say 555 K to generate the Tr=1.5 line. Vary pressure from 42.7 to 300 bars (Pr 1 to 6). Use propane tables to find v (specific volume) solve for Z. Plot Tr(Z,Pr)
| May6-10, 06:42 PM | #3 |
After solving the Van der Waals equation for the compressibility factor and
deriving the critical temperature, pressure, and volume knowing that a horizontal inflection point occurs on the isotherm at critical point am I supposed to solve PV3-(Pb+RT)V2+aV-ab=0 for the cubic root? |
| Thread Closed |
Similar discussions for: [Thermo] Derivation of compressibility factor vs reduced pressure
| pressure at a centroi thermo fluids | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Landé g factor derivation | Advanced Physics Homework | 4 | ||
| Stat/Thermo Problem - Equilibrium Pressure in Permeable Sphere | Advanced Physics Homework | 1 | ||
| Thermo Derivation | Classical Physics | 3 | ||
| derivation of reduced mass | Advanced Physics Homework | 3 | ||
