Prove Limit of Integral Estimate: Zero
  • Thread starter Thread starter Malmstrom
    Estimate Integral
Malmstrom
I have to prove that the solution of an ODE can be continued to a function \in \mathcal{C}^1(\mathbb{R}). The solution is:
e^{-\frac{1}{x^2}} \int_{x_0}^x -\frac{2e^{\frac{1}{t^2}}}{t^2} dt
It is clear that this function is not defined in x=0. Its limit for x \rightarrow 0 though, seems to be zero. How do I prove it?
Actually prove that the limit is zero.
Should I use the dominated convergence theorem? Can't find the right function to dominate this one...
have you tried power expanding the exponentials in powers of \frac{1}{x^2}?
may need some extra thought regarding convergence, so not sure whether it will work, but has nice from for it, so may be worth a crack...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
