Voltage pulse from ignition coil ?
The discussion revolves around the voltage characteristics of ignition coils, particularly focusing on the voltage pulse generated during operation. Participants explore various aspects including theoretical voltage levels, practical measurements, and implications for using oscilloscopes and tachometers. The conversation includes both technical explanations and personal experiences related to ignition systems.
  • Some participants suggest that the voltage from an ignition coil can reach tens of thousands of volts, with estimates ranging from 12,000 volts for average engines to 50,000 volts for high-performance coils.
  • Others argue that the voltage seen on the negative terminal of the coil during operation can spike to over 100 volts when the points open, due to the collapse of the magnetic field in the coil.
  • One participant notes that the voltage can be theoretically infinite but is practically limited by breakdown voltage and other factors.
  • There are discussions about the need for voltage dividers when measuring high voltages with oscilloscopes to prevent damage to the equipment.
  • Some participants mention the importance of understanding the inductive voltage spike on the primary coil and the implications for measuring devices like tachometers.
  • One participant shares a personal anecdote about the dangers of high voltage, emphasizing the need for caution when working with ignition systems.
  • There is mention of using frequency-to-voltage converters for logging RPM, with discussions about the necessary input frequency and circuit configurations.
Participants express a range of views on the voltage levels associated with ignition coils, with no consensus on specific values or measurements. The discussion remains unresolved regarding the exact characteristics of the voltage pulse and its implications for measurement techniques.
Some participants highlight the complexity of measuring voltage in ignition systems, noting factors such as the inductive nature of coils, the role of capacitance and resistance, and the specific configurations of ignition systems (e.g., points vs. solid-state). There are also references to the limitations of standard resistors when dealing with high voltages.
This discussion may be of interest to automotive engineers, hobbyists working on ignition systems, and individuals involved in measuring electrical signals in automotive applications.
kuhl0040
Voltage pulse from ignition coil ??
Hi,
Does anyone know the voltage of the pulse from a typical ignition coil?
thanks.
tyler
If you are referring to the engine's coil of ignition keep on reading. If not, excuse me for not understanding you well enough.
The voltage can be deduced without learning it by heart. You only have to know what is the rupture voltage of the air. We will take along air as the approximate component inside cylinder, although a fuel air ratio exist.
The typical rupture voltage of the mixture is 6 KV/mm. It means, this voltage has to be reached in order to initiate the spark ignition and ionizate the mixture. The typical distance between spark plug electrodes is roughly 2 mm. Thus, 6*2=12 KV have to be provided by spark plug (i.e the coil's secondary circuit.
It's only a numeric approach, but it takes after real engines very well.
I am looking for the amount of voltage seen on the negative side of the coil terminal. So if I hooked up an oscilliscope to the negative terminal of my ignition coil what would the waveform look like?
Thanks,
Tyler
So you're trying to measure the inductive voltage spike on the primary coil? It'll likely be in the hundreds of volts, you'll likely want to use a voltage divider to avoid damaging the input to your scope.
Cliff
>Does anyone know the voltage of the pulse from a typical ignition coil?<
In theory the voltage is infinite. The voltage in practice is limited by brake down of air or insulation between the terminals. The voltage will also be limited by the rate that you are able to remove the energizing connection. If you remove the connection slowly the energy in the coil will dissipate in the arc of that connection. Other factors will also influence the voltage but I don’t think they will be important to you in real life.
>So you're trying to measure the inductive voltage spike on the primary coil? It'll likely be in the hundreds of volts, you'll likely want to use a voltage divider to avoid damaging the input to your scope.<
The secondary of the induction coil will be thousands of volts. If you try to measure that voltage normal resistors will brake down and damage will result. Consult the voltage allowed across each resistor then use a number of resistors in series to handle the expected voltage.
If you are using this with a normal spark plug you will find you primary voltage to be about 200 volts,
So the signal an aftermarket tachometer uses is in the hundreds of volts?
For an average car engine expect something in the order of 12,000 volts, although BMWs are notorious for their high energy ignition systems, around 45,000 volts off the top of my head.
(Not literally off the top of my head, that would hurt lots, a bit like the time my mate started an engine while I was holding the top of the spark plug...)
Just a thought -- the ideal voltage is not infinite -- all coils have both capacitance and resistance which cannot be ignored and are in effect resonant circuits -- however the 'unloaded voltage' is definitely in 10's of thousands of volts and can give the unwary a nasty shock -- so take care.
The coil is an autoformer that only has so much of a step up ratio like 100:1 so if you want 50,000V at the seconday then you need 500V at the primary.
High voltage rated resistors are available up many KV, mouser has some that are 1KV, $3.25, 1Mohm, and in-stock.
Maybe an opto-isolator after the op-amp after the voltage divider? :smile:
Autoparts stores have tachs for under $20, might want to investigate that way. If you're lucky, someone at one of those stores has one that doesn't work anymore, they don't last long at that price point...
Cliff
i guess i should explain what I'm trying to do. I need to log rpm, and my dataq logger needs a +- 10 volt analog signal, thus I'm trying to use a frequency to analog voltage circuit using a lm2917. I think I am using the right diagram, the one that's attached, but the guy at National Semiconductor said i need to what kind of input frequnency is used. I can use the 8 pin lm2917 if the input frequency goes pos. and neg. but if it's only 1 polarity then i need the 14 pin lm2917. Any ideas?
Thanks,
Tyler
Here's the attached diagram and link to the frequency to voltage converter i want to use. http://www.national.com/ds/LM/LM2907.pdf
tyler
What are you wanting to log rpm info for?
Anyhow, ever heard of a lil gadget called Gtech?
http://www.gtechpro.com/gtechprocomp_howitworks.html
Engine RPMs are sensed directly from the cigarette lighter voltage. No installation required at all with this true plug and play feature. The unique RPM feature is used for anything from realtime torque measurements to shiftlights.
So the engine rpm is reflected throughout the cars electrical system. Figuring out how to get this into usable info, I do not know.
It seems like there are a few posters on here that are confused. The OP is NOT concerned with secondary voltage. Secondary voltage for those who do not know is the voltage that ends up on the spark plug.
Original poster IS concerned about voltage he would see on the 'points'. Realize that I refer to points in a generic manner. A conventional ignition system with points make and breaks contact between the negative side of the ground. A conventional solid state ignition does the same thing except the points are replaced by a solid state switching device such as a transistor. Current flows into the positive side of the coil and out through the negative terminal into the 'points' to ground. When the plug is supposed to fire the points open. There is a slight arcing that is quenched by a capacitor placed across the points. The points stay open as long as possible. But they have to close again soon enough to guarantee the field will have enough time to build up in the ignition coil before the plug is ready to fire again. Those who remember actual points systems will know that the time the points stay closed is called dwell and is measured in degrees of the distributor shaft. With solid state ignition dwell has pretty much been eliminated except by the designers of the ignition system.
Now concerning the original posters question, the voltage you can expect to see on the negative side of the coil will go as follows:
'Points' closed, voltage will be close to zero. Period of time goes by and the points open. Voltage immediately spikes to 100 or more volts. This is due to the same reason the voltage on the secondary suddenly jumps to thousands of volts. The magnetic field in the coil collapses. A turns ratio difference causes the spikes to be lower on the negative side of the coil than the secondary. The spike drops back down as fast as it rose. There can be some steps in this waveform caused by the breakdown of air/fuel charge on the spark plug. The voltage finally levels out at about 12 to 14 volts until the points close again.
I don’t understand why you are having a problem. You have a data sheet that shows you how to connect the circuit to the coil on page 10. The circuit is designed to function with the voltage expected at that connection.
You may want to experiment and just wrap a wire around the HV output of the coil. The pick up through the capacitance should be enough to use. You may need to change the value of the input resistors and capacitor. For added protection if the insulation on the coil wire should break down you may want to put a diode to ground and the plus 12V at the input of the chip.
  • · Replies 22 ·
  • · Replies 34 ·
  • · Replies 48 ·
9K
