How High Must a Satellite Orbit to Maintain Specific Gravitational Strength?
  • Thread starter Thread starter the_morbidus
    Earth Satellite
To maintain a gravitational strength of 4.5 N/kg, a satellite must orbit at an altitude of 3.02 million meters above Earth's surface. The calculations for this altitude involved using the gravitational force equation and Earth's mass and radius. The required orbital speed for the satellite is approximately 11,489.16 m/s. For determining the acceleration and direction of the satellite, applying Newton's second law is recommended, as the period is not known. The initial calculations for parts a and c are confirmed to be correct.
the_morbidus
A satellite is designed to orbit Earth at an altitude above its surface that will place it in a gravitational field with a strength of 4.5 N/kg.
a) Calculate the distance above the surface of Earth at which the satellite must orbit.
b)Assuming the orbit is circular, calculate the acceleration of the satellite and its direction.
c)At what speed must the satellite travel in order to maintain this orbit?
Given values in the book:
mass of Earth : 5.98 x 10^24 kg
radius of the Earth : 6.38 x 10^6 m
g : 6.67 x 10^-11 Nm^2/kg^2
Fg= G mE / r^2
ac=v^2/r
v= sqrt ( GmE/r )
ac= 4Pi^2 r / T^2
a) So we have to find the distance of the satellite above the surface of the Earth and for that we will find its distance from the centre of the Earth and then subtract it from the Earth's radius to obtain the final result.
Fg= GmE/r^2
4.5=(6.67x10^-11)(5.98x10^24) / r^2
r^2= 3.98866x10^14 / 4.5
r= sqrt (8.8637x10^13)
r=9.4x10^6 m
r surface = r total - r earth
r surface = 9.4x10^6 - 6.38x10^6
r surface = 3.02x10^6 m
The satellite must orbit at 3.02x10^6 m from the surface of the earth.
b)
This is the one i don't get it althought I'm not sure which one the centripetal acceleration formulas to use, i have no idea how to figure out its direction, please help !
c)
v= sqrt (GmE / r)
v=sqrt ( (6.67x10^-11)(5.98x10^24)/3.02x10^6)
v=sqrt (3.98866x10^14/3.02x10^6)
v=sqrt (1.32x10^8)
v=11489.16 m/s
The satellite must travel at 11489.16 m/s in order to maintain its orbit.
again if possible to help me with question b) and perhaps review my work for questions a) and c) , thank you everyone!
The principles of a and c are right, so as long as you did the numbers okay, those looks good.
For part b), try using Newton's second law since you don't know the period. :)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
