The discussion revolves around the calculation of eigenvalues of total angular momentum and the associated matrix elements between different quantum states. Participants explore the notation and methods for expressing these states, particularly in the context of three-particle systems.
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant asks for the formula to calculate the matrix element of total angular momentum between two states, specifically
- Another participant questions the clarity of the notation used, suggesting that the problem may be trivial if the quantum numbers are correctly defined.
- A third participant provides a response indicating that the matrix element can be expressed with delta functions, implying a straightforward solution.
- One participant expresses confusion about the notation and suggests that the eigenkets should be represented in a different form, noting that the eigenvalue of J² is given by \hbar² j(j+1) rather than j².
- A later reply discusses the complexity of calculating the matrix element if using a specific notation for three particles, mentioning the need to fix the projection and the combinations of single particle states.
- The same participant proposes a formula for calculating the matrix element and describes the process of diagonalizing the resulting matrix to find eigenstates of total angular momentum.
- There is an acknowledgment of a poorly formed initial question, indicating a shift in focus to a more complex scenario involving three particles.
Participants express differing views on the clarity and complexity of the problem, with some suggesting it is trivial under certain conditions while others highlight the complications that arise in multi-particle systems. No consensus is reached on a definitive approach or solution.
Participants reference specific quantum states and their representations, indicating that assumptions about notation and definitions may impact the clarity of the discussion. The complexity of the calculations for three particles remains unresolved.
