Tricky probability question
  • Thread starter fraggle
  • Tags
    Probability
In summary, the probability of obtaining exactly 1 head is 3/7, the probability of obtaining exactly 2 heads is 3/8, and the probability of obtaining exactly 3 heads is 1/8. There is a flaw in the first method as it only counts the outcomes with exactly 1 head, and in the second method, the probability is conditioned on obtaining at least one head. The unconditional probability of obtaining exactly 2 heads is 3/8.
fraggle
A coin is tossed 3 times. at least 1 head is obtained. Determine each probability...?
1) exactly 1 head is obtained
2) exactly 2 heads are obtained
3) exactly 3 heads are obtained.
for 1) brute force indicates that there 7 possible combinations:
HHH, HHT, HTH, HTT, THH, THT, TTH (because at least one heads is obtained).
Out of these we see that there are 3 occasions where there is exactly one heads.
If we let S be the sample space of all possable outcomes, and let E be the event of having exactly one heads, then a basic rule of probability indicates that the probability P(E)=|E|/|S|=3/7.
However, using another method:
fix one coin throw's result as heads. Then the probability of the other two throws being tails is (1/2)(1/2)=1/4.
Since we can fix heads 3 times, this indicates that the probability is 3(1/4)=3/4.
Can anyone spot where the flaw is in either of these attempts at a solution?
thanks
(this isn't a homework question btw)
3/7 is a conditional probability given at least one head. For the unconditional probability you need to count TTT among the outcomes.
3/4 is the conditional probability of two tails given (one) head. "Head" has probability 1/2, so the unconditional probability is 3/4 x 1/2 = 3/8.
1. What is a tricky probability question?
A tricky probability question is a problem that involves using probability concepts and principles to solve a complex or difficult situation. These types of questions often require creative thinking and a deep understanding of probability to come up with the correct answer.
2. How do I approach a tricky probability question?
The best approach to solving a tricky probability question is to break it down into smaller, more manageable parts. Start by identifying the given information and what is being asked in the question. From there, apply the relevant probability principles and use logical reasoning to arrive at a solution.
3. What are some common probability principles used in tricky questions?
Some common probability principles used in tricky questions include the rules of multiplication and addition, conditional probability, Bayes' theorem, and the principle of complementary events. It is important to have a good understanding of these principles to successfully solve tricky probability questions.
4. How can I improve my problem-solving skills for tricky probability questions?
One way to improve your problem-solving skills for tricky probability questions is to practice solving different types of problems. Look for sample questions or create your own, and try to solve them using different approaches. This will help you become more comfortable with applying probability concepts and improve your ability to think critically.
5. Are there any resources available to help with tricky probability questions?
Yes, there are plenty of resources available to help with tricky probability questions. Some good sources include textbooks, online tutorials, practice problems, and study groups. It can also be helpful to work with a tutor or seek guidance from a teacher or professor if you are struggling with a specific concept or problem.
