Calculating Output Time for an Electric Wheelchair | 12V Batteries & 1hp Motor
  • Thread starter Thread starter Juntao
The discussion focuses on calculating the output time for an electric wheelchair powered by two 12V lead acid batteries and a 1 hp motor with an efficiency of 89%. The total energy capacity of the batteries is 1200 W-hrs. To determine how long the motor can run, the effective power consumption of the motor, calculated as 838 W (1.12 hp), is used. The final calculation shows that the motor can operate for approximately 1.43 hours, or 86 minutes, before requiring a recharge.
  • Understanding of electrical power calculations (P = V * I)
  • Familiarity with energy capacity units (W-hrs)
  • Knowledge of motor efficiency and its impact on power consumption
  • Basic conversion between horsepower and watts (1 hp = 746 W)
  • Research battery capacity calculations for different battery types
  • Learn about electric motor efficiency and its implications on performance
  • Explore advanced power management techniques for electric vehicles
  • Investigate the impact of load on battery life in electric mobility devices
Engineers, hobbyists, and anyone involved in electric vehicle design or optimization, particularly those working with electric wheelchairs or similar applications.
Juntao
help with simple problem:(
An electric wheelchair is powered by two 12 V lead acid batteries and an electric motor rated at a maximum output power of 1 hp. Each battery has an energy capacity of 600 W-hrs. The motor has an efficiency rating of 89%. Assuming that the batteries are fully charged, for how many minutes can the motor deliver the rated output power before the batteries must be recharged?
Ok, this seems such an easy problem, but I can't get it to work just yet.
I know that P= V*I
and Energy = P_avg*Time
1 hp = 746watts
Ok, so I have two batteries, each battery has capacity of 600 W-hrs, so total I have 1200 W-hrs.
In the end, I want to be able to take the 1200 W-hrs, divide by some number of watts to get hrs, then convert hrs to mins.
But I do not know how to use the 89%. I thought maybe I have to use the hp conversion factor, so I tried doing this, 1200 W-hrs/(746W*.89)*(60min/1hr) but that didn't work. Can somebody lead me in right direction?
The motor is 89% efficient. It takes in more power than it puts out, and converts the rest to heat. What power must it take in that when multiplied by 0.89 is 1 hp?
1 hp / 0.89 = 1.12 hp.
The motor must take in 1.12 hp, 89% of which is converted into 1 hp of output power.
Now convert 1.12 hp into watts:
1.12 hp * (746 W / 1 hp) = 838 W
How many hours will the 1200 W-hr battery pack run the motor?
(838 W * ? hr) = 1200 W-hr
The result is just a division. 838 W for how many hours is the same total energy as 1200 W for 1 hour?
- Warren
awesome
thank you so much...you are a true godsend.
  • · Replies 26 ·
  • · Replies 21 ·
10K
25K
  • · Replies 16 ·
  • · Replies 18 ·
17K
