How to solve the differential equation e^y-1/y'=1 ?
The discussion revolves around solving the differential equation e^y - 1/y' = 1. Participants are exploring the methods and reasoning involved in approaching this equation, which falls under the subject area of differential equations.
  • Some participants discuss the need for clearer notation and the requirement to show initial work before receiving help. Others mention attempting to find an inverse function and express confusion about the implications of their manipulations. There is mention of using separation of variables and integrating, as well as the introduction of the Lambert W function as a potential avenue for expressing the solution.
The discussion is ongoing, with various approaches being suggested, including integration techniques and the use of special functions. Participants are questioning the validity of their steps and exploring different interpretations of the problem without reaching a consensus.
Participants note that they are working within the constraints of basic techniques for solving differential equations and express uncertainty about the applicability of these techniques to the problem at hand.
NegativeGPA
Does anyone know how to solve the differential equation
e^y-1/y'=1
e^y-1/y'=1
Welcome to the PF. Could you please use parens or Latex to make the equation clearer for everybody? Also, you are required to show a little work on the problem before we can help you (see the PF Rules link at the top of the page). Do you have an idea of what first steps you should take to work toward a solution?
Is it: [tex]e^y -\frac{1}{\frac{dy}{dt}} = 1[/tex] ?
yep, sorry about that.
My original problem was trying to find an inverse of y=e^x+x and so I differentiated it and got that equation. So far the closest I've gotten is y=ln(x-1) but then i realized that gave me 1=0, so that obviously doesn't work.
I started trying plugging different values into make some directional fields but it's not doing much towards giving me a solid answer, and I haven't learned more than the basic techniques to solve differential equations, and none of them apply to this, so I was seeing if anyone else had any ideas.
Standard separation of variables should do the trick. The problem is, you arrive at a solution which cannot be solved explicitly in terms of y, just as your original problem was unsolvable (in terms of elementary functions) for x.
e^y-1/y'=1
Multiplying through by y', [itex]y'e^y- 1= y'[/itex] so [itex]y'(e^y- 1)= 1[/itex] and that results in [itex](e^y- 1)dy= dx[/itex].
That's not at all hard to integrate.
Differentiating your equation and then trying to integrate it will just give you back your original equation:
[tex]x = e^y + y \Rightarrow 1 = (e^y +1)\frac{dy}{dx}[/tex]
which you rearranged into [itex]1/y'(x) -e^{y(x)} = 1[/itex]. (or close to it - it looks like there's a sign mistake). Solving this equation, however, will just give you back your original equation [itex]x = e^y + y[/itex].
To solve this in terms of a known function that you can use in Mathematica, exponentiate both sides:
[tex]e^x = e^y e^{e^y}[/tex]
This is now in a form which defines the Lambert W function: [itex]z = W(z)e^{W(z)}[/itex]. Hence,
[tex]e^{y(x)} = W(e^x) \Rightarrow y(x) = \ln W(e^x)[/tex]
From the definition of the Lambert W function, we can also write [itex]\ln z = \ln W(z) + W(z)[/itex], so using this we may write the solution as
[tex]y(x) = \ln e^x - W(e^x) = x - W(e^x)[/tex]
A note on the Lambert W function: this is a multivalued function, so there are really infinitely many branches, denoted by n: [itex]W_n(z)[/itex], where z can be complex. The principal branch, n = 0, and the branch n = -1 are real valued for real valued inputs.
  • · Replies 18 ·
  • · Replies 33 ·
