Thread Closed
Reinventing solar power
Share Thread Thread Tools
Jun23-10, 02:21 AM   #1
Hello,
I am not sure if I am posting in the right place, but here are my thoughts.
I don't exactly understand how solar cell works, but it has to do with photons knocking out electron which makes the current flow.
So I thought about the WiFi based charger. It generates electricity from WiFi waves, right? Which are electromagnetic, like visible light. In that case, could we use same principle to generate electricity from visible light waves?
Any thought appreciated.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
>> NASA: Austin, calling Austin. 3-D pizzas to go
Jun23-10, 02:28 AM   #2
I don't understand what you are asking. PV cells generate electricity from the visible light spectrum. Are you looking for another device that can as well but based on different principles?
Jun23-10, 02:43 AM   #3
Basically I am asking two thing: does WiFi signal based charges generates electricity differently than PV cells and if so could we use same principle that WiFi charger uses (since WiFi signal is electromagnetic wave and visible light is electromagnetic waves) to generate electricity from visible light (or even all electromagnetic waves that travel).
Sorry if I don't express my self understandably - English isn't my native language.
Jun23-10, 05:19 AM   #4
Acutally you "generate" electricity within all types of antennas.
But the energy in a wifi signal (2.4GHz) is much lower than a visible light wave. E=h*v
A powerfull wifi router has a output of 1 Watt, in all directions. How much power do you think you can generate with a antenna/panel e.g.?
Jun23-10, 05:33 AM   #5
SirAskalot, I am not sure I understand your question. So the idea is to transform that energy (what ever amount it is) to electricity. And the PV cells are not antennas for visible light, right? So is it possible to create one, and would it "generate" electricity?
Jun23-10, 06:09 AM   #6
Wasnt really a question, just a comparison on how little energy/power you can produce. <1W aint really somthing to shout hurray about.
The question is whether you find a semiconductor in the PV that has a lower energy gap than the energy of the wifi photon. Else it wont "knock of a electron". I dont know the answer to this.
Jun23-10, 12:44 PM   #7
Mentor
Quote by aladin777 View Post
A tuned antenna will generate a terminal voltage in response to incoming EM waves. However, the amplitude of that AC terminal voltage is related to the wavelength and the incoming power.
For WiFi antennas, the terminal voltage is tiny (mV to uV), so you cannot derive useful power from WiFi background radiation.
Jun24-10, 07:21 AM   #8
Recognitions:
Gold Membership Gold Member
The nearest (if not the only) example of a device that is worked solely by received radio waves is the old Crystal Set. It necessitates a long wire, not because of the long wavelengths involved but because the RF fields around your house are a very few millivolts per metre, even from a large broadcast transmitter. The induced RF voltage is then tuned to match the wire to the detector (and to give you some selectivity) and the signal is rectified. Your ears are just sensitive enough to make use of the tiny amount of energy received.
The signal levels from any WIFI / Bluetooth or mobile phone are so minute that they are only detected after amplification - no chance of driving anything with it - or even charging batteries, I'm afraid. After all, these systems run on the minimum power possible so that the devices can run for hours on batteries.
Jun25-10, 09:14 PM   #9
This is actually a very interesting question. I know how PV cells work, in terms of quantum mechanics (photon hits electron, electron leaves orbit, etc.) I also know how antennas work, in terms of classical EM (changing magnetic field induces a potential). But... how do antennas work in terms of quantum mechanics? What is the fundamental difference between PV and antennas?
Jun27-10, 10:22 AM   #10
I always thought regular RF antennas generated electricity through the changing magnetic and electric fields of the signal wave, in contrast with the photon interaction of PV - correct me if im wrong. Almson proposes a good question.
Jun27-10, 10:39 AM   #11
Recognitions:
Homework Helper Homework Help
Quote by Blenton View Post
You're correct.
You can't detect visible wavelegths directly with an antennea because the frequncy is too high. (It's all to do with resistance and skin effects and other transmission line theory stuff that I forgot)
But the efficiency of photon->electron in a semiconductor is pretty good, not sure a radio type receiver would be any better
Jun27-10, 11:03 AM   #12
My idea was that if there is a charger that can charge phones with WiFi waves so do PV cells use the same principle for getting electricity?
If not then is it possible to make some kind of device that would do that.
And from that there was an idea to make a device which would get electricity from all EM waves.
Jun27-10, 11:10 AM   #13
Recognitions:
No - wifi chargers are basically radios. In a radio the electromagnetic field in the air makes current flow in an antenna and you detect this tiny current to receive the radio signal (or try and use it to charge a battery)
In a solar cell a single photon knocks an electron out of an atom and makes electricity directly.
The problem of doing it the other way around is wavelength - as you go to higher frequencies of EM the wavelength gets shorter, thats why you see giant radio towers for AM radio (100Khz), but have a small car antenna for FM (100MHz) and the antenna for your cell phone (2GHz) is tiny.
When you get to light you would have an antenna impossibly small and the current would have to flow in a surface layer much smaller than an atom - all sorts of QM effects kick in and transmission line theory fails.
Similarly if you try and make a semiconductor detector for radio you would need a huge crystal so that a metre long wave would be absorbed and you would need electrons impossibly weakly held to the atom so that they could be knocked off by low energy radio photons.
There is a very interesting area where these two technologies overlap - it's currently somewhere in the microwave bands.
Jun27-10, 11:34 AM   #14
Quote by mgb_phys View Post
But visible light wave length is much longer than size of an atom, so may be we just don't have the right nano technology?
Jun27-10, 01:11 PM   #15
It's possible by using carbon nanotubes as antennas
http://www.zpenergy.com/modules.php?...rticle&sid=948
Jun27-10, 01:47 PM   #16
Quote by DrZoidberg View Post
Now to make "antennas" that could convert electricity from as wide EM wave range as possible and we could have the ultimate power cells :]
Jun27-10, 02:22 PM   #17
Recognitions:
Quote by almson View Post
That's rather an over simplification. Electrons don't "leave orbits" when light hits a PV cell - or any other solid, in fact. You don't have orbits or specific energy levels and a photon doesn't react with one electron (as in the simple Hydrogen atom model). An electron will move because of the interaction of a photon with the larger structure of the semiconductor and the energy is in Bands rather than Levels This is also what happens when a radio wave interacts with a metal antenna. The difference, for a PV cell is that electrons tend only to flow in one direction and it gives you DC. With visible light, the energy associated with the photons is enough to 'get over' the voltage required to get past the PN barrier (the diode forward voltage drop). In a metal, the electrons move very easily (the band gap is tiny) and the low energy photons (if you really insist on using the idea for RF) can still shift them in either direction.
Thread Closed
Tags
green energy, reinvention, solar power
Thread Tools
Similar Threads for: Reinventing solar power
Thread Forum Replies
solar boat having solar panel power problem General Engineering 13
Solar Power Article General Engineering 1
Solar Power Satellites Mechanical Engineering 7
lunar solar power Current Events 2
solar power General Engineering 1
