 Quote by dEdt
Why is γ = F/2l and not F/l? It says something about there being two surfaces, but it seems to me that because there's only one surface touching the wire, it should be F/l.
The sheet of liquid has two surfaces. See Fig 3, which calls them the upper and lower surfaces.
Second question: In example one, surface tension is applying a force outwards on the needle. But based on the introductory explanation of surface tension, I thought surface tension was only inwards. I can see why compressing the liquid will produce some outward force against the needle, but why would that equal γL? It seems like those are two different phenomena.
The surface is always under tension, just like a piece of taut rope. (Imagine it as a stretched rubber sheet.) The tension is always tangential to the surface. The needle rests on the surface (which bends around it), and the surface exerts a tangential force, which in this case has a vertical component that balances the weight of the needle.
Part of the confusion may be the diagrams in Fig 2, which are inaccurate. Fig 2a implies that the inside of the liquid is under tension, when it's really under compression; Fig 2b implies that there's a net inward force at the surface, which would produce an inward acceleration.
