Would an energy diffraction ring in five space form a Minkowski space?
This discussion explores the concept of energy diffraction rings in five-dimensional space and their relationship to Minkowski space. The user proposes that a spherical symmetric diffraction ring can be analyzed through energy overlap and distance metrics, suggesting that such patterns may exhibit three elliptical and one hyperbolic dimension. The conversation highlights the complexity of defining energy distributions and the challenges of articulating coherent questions within advanced physics topics, particularly regarding the implications of expanding space and the nature of vectors in Minkowski metrics.
  • Understanding of Minkowski space and its dimensional properties
  • Familiarity with diffraction patterns and wave mechanics
  • Knowledge of vector mathematics in non-Euclidean geometry
  • Concepts of energy density and its relation to spacetime metrics
  • Research the properties of Minkowski space and its application in modern physics
  • Study the principles of diffraction patterns and their mathematical representations
  • Explore the implications of expanding universe models on vector divergence
  • Investigate the relationship between energy density and spacetime metrics in general relativity
Physicists, mathematicians, and students interested in advanced concepts of spacetime, energy distribution, and the interplay between geometry and physics.
TCS
If you think of a sphereical symmetric diffraction ring, the intensity is constant for each sphereical section (intensity doesn't vary for theta or phi), but it varies kind of like a sine wave in the r dimension from zero to zero with a maximum in the middle of the ring. So that if you think about a vector as being an object that has an energy intensity defined throughout the entire ring, such as another diffraction pattern imbedded in the ring, then I believe that the distance between two such imbedded patterns can be defined as the energy overlap of the patterns. Since the ring sphereically symmetric but thinned out in the r direciton, I believe that it can be thought of as having two eliptical and one hyberbolic dimension. Moving into the r dimension makes things farther apart because the energy overlap becomes less.
Accordingly, I'm thinking that a similar four dimensional diffraction pattern should provide three eliptical and one hyperbolic dimension for determining the closeness of embedded diffraction/distributed energy patterns, which I think should follow the Minkowski metric.
although, I'm not quite sure how to define the energy distributions to make it all work out.
I was just rying to work out the idea of what Minkowski spaces are but it seems to me know that it is the expansion of space with time that causes the Minkowski nature of space.
None of this makes even the remotest bit of sense. This is rather a feature of many of your posts, where you mix jargon from entirely unrelated areas of physics and expect others to make sense of the resulting mess for you.
Please, if you have a serious, well-defined question, ask it. But questions like this serve only to waste everyone's time.
I'm sorry to waste your time.
Doesn't a metric provide the distance between two vectors.
Can't standing waves and diffraction patterns be considered vectors?
Isn't Minkowski space comprised of three eliptical and one hyperbolic dimension?
http://www.euclideanspace.com/maths/geometry/space/nonEuclid/minkowski/index.htm
In Euclidean space, you can measure the distance between any two identical but spacially separated vectors by the distance between them at any two points, but you can't do that in a coordinate system where the parallel postulate doesn't hold.
If one dimension is expandng (the vectors are getting farther apart), then the dimension will be hyperbolic an the parallel postulate will not hold.
Since the universe is expanding, parallel vectors in x,y,z become divergent vectors as they move through T.
Is there any other mixed jargon that I used?
If you consider vectors painted on an inflating ballon, the distance between the vectors should follow a Minkowski like metric in three dimensions; and if you correlate energy density to rubber density (elasticity), the vectors on the inflating dimple shaped balloon should have a GR type metric.
So if you think of energy as being the inverse dimension of time, it is analalogous to the top half of a diffration pattern being time and the bottom half being energy, where a vector is a wave pattern distributerd pattern between the upper hyberbolic half diffraction pattern ands a lower eliptical diffraction pattern.
Although I'm sorry about asking a question before I had taken more time to think it through. Sometimes I get stuck on an idea and I want to find a resolution but what I really need to do is to take walk or a nap to let my mind reconfigure it's understanding.
  • · Replies 21 ·
  • · Replies 0 ·
