XRD/XRR v. AFM for Film Thickness
  • Context: Graduate
  • Thread starter Thread starter IntentKnown
    Film Thickness
The discussion evaluates the effectiveness of X-ray Reflectometry (XRR), Atomic Force Microscopy (AFM), and Scanning Electron Microscopy (SEM) for measuring the thickness of a wedge-shaped PZT sample layered with LSMO. The wedge varies from 50nm to 0nm across its length, and the AFM is recommended as the simplest method for obtaining thickness measurements, with a z-resolution of up to 0.5nm. XRR can provide reliable thickness and roughness values using the Parratt formalism, but requires careful beam constriction due to the sample's non-standard shape. SEM can also be utilized for cross-sectional analysis but involves more complex sample preparation.
  • Understanding of X-ray Reflectometry (XRR) and its application in thin film analysis.
  • Familiarity with Atomic Force Microscopy (AFM) techniques and their resolution capabilities.
  • Knowledge of Scanning Electron Microscopy (SEM) and Transmission Electron Microscopy (TEM) for material characterization.
  • Basic principles of film thickness measurement and material layering.
  • Research the Parratt formalism and its application in XRR for thin film analysis.
  • Learn about the operational principles and setup of Atomic Force Microscopes (AFM).
  • Explore the sample preparation techniques required for Scanning Electron Microscopy (SEM) and Transmission Electron Microscopy (TEM).
  • Investigate methods for measuring film thickness in non-standard geometries using XRR and AFM.
Researchers, material scientists, and engineers involved in thin film characterization, particularly those working with complex geometries and layered materials.
IntentKnown
Currently in our lab we have a WEDGE shaped sample that we would like to be able to know the thickness at various points along it. Our sample is about 5mm x 5mm. The wedge SHOULD extend from one side to the other. At the highest point, the wedge is 50nm, and then drops down, hopefully at a constant rate, to 0nm at the other side.
**Special Note**
The wedge is made of PZT and is between two layers of LSMO, with the layer on top of the wedge measuring a constant 5nm.
We were thinking about using the XRR/XRD to find the thickness, but I've recently been told to try the Atomic Force Microscope because of our unique shape, and even perhaps the Scanning Electron Microscope.
I have no personal experience using either the AFM or the SEM and have no idea how they would compare to using the XRR
Thoughts/ Concerns from the forum please.
Hi,
I think all three of the techniques you mention could answer your question:
XRR: thickness interference fringes in XRR can be modeled with the Parratt formalism (e.g. using Parratt32.exe), and give very reliable thickness and roughness values (~0.1 nm precision for good data and fits). As your sample shape is non-standard, you would have to constrict your x-ray beam to ~0.1 mm sideways, so as to not sample the whole wedge but just a part of it. This is doable on a good reflectometer, but you sacrifice a lot of flux, which makes it challenging
AFM: I do not know what the abbreviations of your materials stand for, but if you can make a scratch down to the substrate you can scan the scratch then and (taking care to look beyond the bulge) extract film thickness. z-resolution should be up to 0.5 nm.
SEM / TEM: You could break your sample an look at the cross section. IN SEM one would expect a resolution of 10nm, TEM where sample preparation would be much more involved can get much more precise.
I would try AFM first (simplest), then XRR.
  • · Replies 0 ·
10K
  • · Replies 24 ·
