What Position Does the Woman Reach When the Beam Tips?
In summary, a beam with a length of 6.00 m and mass of 72.0 kg is supported by two pivots. A woman with a mass of 51.1 kg steps onto the left end and begins walking to the right. The goal is to find the woman's position when the beam begins to tip. To do this, we use the force equation of equilibrium to find the normal force n1, which is 0 N. Then, using the torque equilibrium equation with the torques computed around the second pivot point, we find that the normal force n2 is 1206.38 N. Finally, we use the equation for torque and consider the net torque before the beam begins to tip to find the
mandy9008
127
A beam resting on two pivots has a length of L = 6.00 m and mass M = 72.0 kg. The pivot under the left end exerts a normal force n1 on the beam, and the second pivot placed a distance l = 4.00 m from the left end exerts a normal force n2. A woman of mass m = 51.1 kg steps onto the left end of the beam and begins walking to the right as in the figure below. The goal is to find the woman's position when the beam begins to tip.
[PLAIN]http://www.webassign.net/sercp8/p8-12.gif[/IMG
a. What is n1 when the beam is about to tip?
b. Use the force equation of equilibrium to find the value of n2 when the beam is about to tip.
c. Using the result of part (a) and the torque equilibrium equation, with torques computed around the second pivot point, find the woman's position when the beam is about to tip.
a. n1=0 N
b. n2=mg
n2= (51.1kg)(9.8 m/s2)
n2=500.78 N
c. since F is 0 in part a, I would think that this answer will be zero as well
You have to include the mass of the beam itself as-well.
okay, so n2 will be 1206.38 instead, assuming that you meant: n2= (51.1kg + 72.0 kg)(9.8 m/s2). so what do i need to do for part c?
That looks about right. Whats the equation for torque? And the instant before it begins to tip, what is the net torque? It might help if you draw a picture of this situation, consider what torques are in what direction, remember to include the beam.
I would like to clarify a few things about the problem and the proposed solution. Firstly, the concept of equilibrium refers to a state in which all forces and torques acting on an object are balanced, resulting in no net acceleration or rotation. In this problem, we are dealing with static equilibrium, meaning the object is not moving or rotating.
Now, let's address the solution provided. In part a, it is stated that n1=0 N. However, this is not entirely correct. Since the woman is standing on the beam, there will be a normal force exerted by the beam on her, which will in turn exert a normal force on the pivot. This normal force will counteract the weight of the beam and woman, and thus n1 will not be equal to 0 N. To find the value of n1, we can use the force equation of equilibrium, which states that the sum of all forces in the x-direction must equal 0. This can be written as:
n1 + n2 - mg = 0
Solving for n1, we get:
n1 = mg - n2
Substituting in the given values, we get:
n1 = (72.0 kg)(9.8 m/s^2) - (51.1 kg)(9.8 m/s^2) = 216.6 N
Therefore, the correct answer for part a is n1 = 216.6 N.
Moving on to part b, the solution provided is correct. We can use the same force equation of equilibrium to solve for n2:
n1 + n2 - mg = 0
Substituting in the given values and solving for n2, we get:
n2 = mg - n1 = (51.1 kg)(9.8 m/s^2) - (216.6 N) = 284.08 N
So, the correct answer for part b is n2 = 284.08 N.
Finally, in part c, we are asked to find the woman's position when the beam is about to tip. To do this, we can use the torque equilibrium equation, which states that the sum of all torques acting on an object must equal 0. This can be written as:
Στ = 0
In this case, we will take torques around the second pivot point, since we are given the distance l from
1. What is equilibrium and how does it relate to pivot points?
Equilibrium is the state of balance or stability in a system. Pivot points are points of equilibrium in a system where the forces acting on the system are equal and opposite, resulting in a stable position.
2. How are pivot points calculated?
Pivot points are calculated using a mathematical formula that takes into account the previous day's high, low, and closing prices. There are several methods for calculating pivot points, including the standard method, Woodie's method, and Fibonacci method.
3. What is the significance of pivot points in financial trading?
Pivot points are used by traders to identify potential support and resistance levels in the market. When the price of a security reaches a pivot point, it can be an indication of a potential change in market direction, making pivot points useful for determining entry and exit points for trades.
4. Can pivot points be used in other fields besides financial trading?
Yes, pivot points can be applied in other fields such as physics and engineering. In physics, pivot points are used to describe the center of rotation in a system, while in engineering, pivot points are used to calculate the stability of structures.
5. Are pivot points a reliable indicator for making trading decisions?
Pivot points should not be used as the sole indicator for making trading decisions. They should be used in conjunction with other technical indicators and fundamental analysis to get a more comprehensive view of the market. Additionally, pivot points should be used in combination with proper risk management strategies to minimize potential losses.
9K
14K
