Thread Closed
A mechanical toy car (without electronics) should turn on detecting obstruction
Share Thread
Jul11-10, 01:05 AM   #1
HI all.
I wanted to make a toy car (except battery and motor completely mechanical) which should turn and move along on detecting an obstruction. I saw such a toy car but unable to get the design. Please help guys...
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jul11-10, 03:44 AM   #2
Not really feasabile to do it by mechanical only. You can do a mechanically programmed car that will move in a certain pattern but not one that will adapt.
The problem boils down to:
Input -> Signal interpretation -> Action
Using purely mechanical means input and signal interpretation are incredibly difficult (read nearly impossible) to achieve.
The action part is really easy, that could be done by rotating a steering wheel by hydraulics or pneumatics or an electric motor that turns a wheel.
Jul11-10, 05:18 AM   #3
Dude Even i was amazed but our sir showed us that and told it is done using some gears and the toy costs less than 100 rupees. It is possible dude ...
Jul11-10, 05:22 AM   #4
Let us know the details then.
Jul11-10, 06:18 AM   #5
Quote by vivsarda14 View Post
When you say 'detecting an obstruction'. Can the car touch the obstruction? If yes then it can be done mechanically, if not then it can't.
I immedately thought of avoiding the obstuction, which requires a non contact sensor. As such the sensor itsself will have an electrical output.
Jul11-10, 07:45 AM   #6
It will touch and then turn ...
Do u no how???
Jul11-10, 08:19 AM   #7
Some sort of leg out front that when it touches an obstruction, will push the car backwards and the front wheels to the side enough times to get it out of the obstructions way. The foot would run all the time (connected to the drive shaft).
Thread Closed
Similar discussions for: A mechanical toy car (without electronics) should turn on detecting obstruction
Thread Forum Replies
How much electronics/chemistry does a Mechanical Engineer have to know? Academic Guidance 0
A mechanical engineering student hating mechanical design Academic Guidance 14
Rate Of Turn and Turn Radius of an aircraft Introductory Physics Homework 2
Electronics to mechanical Electrical Engineering 12
Surgery Obstruction Groups Linear & Abstract Algebra 9
