Does a photon have energy density?
member 141513
Does a photon have energy density??
can anyone help me what a photon behaves when talking about energy density?
it seems that photon just travel through time but not space ,or I am wrong?
can anyone help? thanks so much~~
yes a photon has energy density.
Don't understand the first part of your question: Are you sure you mean energy density??
See here http://en.wikipedia.org/wiki/Energy_density#Energy_density_of_electric_and_magnetic_fields
for the energy density of an electromagnetic field.
Since a photon is a probability function and perhaps also viewed as a point particle, "energy density" doesn't have a lot of value ...No one knows the physical size of any elementary particles...it's "uncertain"...
Have you thought about light (on form of photons) traveling from the sun to the earth??
Light travels to us here on Earth over a period of minutes at an observed velocity close to "c".
I am wondering how a point like particle can have a wavelength. Wavelength implies spatial extension.
Best wishes
DaTario
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
