Morga
- 27
How are artificitial satellites made to point to the surface of the Earth as they orbit? Is it due their spin angular momentum?
Maybe there's a naming issue, based on this quote from the wiki article:D H said:Careful there, rcgldr. The Hubble uses gyroscopes as attitude sensors, not effectors. It uses reaction wheels (momentum wheels) as effectors.
other articles also seem to be conflicting on the termonology.D H said:It's wikipedia. What more need be said?
There's mention of the wheels moving at around 6,000 rpm. Is orientation changed by pivoting the axis (gyroscopic precession) of the wheels or by angular acceleration (torque) of the wheels? Since you mention fixed axis, then I assume it's angular acceleration. If it's angular acceleration, then how is the angular velocity kept within some reasonable bounds?Those reaction wheels on the Hubble ... With the rotation axis fixed to the vehicle it doesn't really count as a gyro though.
Momentum wheels and reaction wheels are two names for the same thing.rcgldr said:other articles also seem to be conflicting on the termonology.
Momentum wheels are similar the rear tires on your car in the sense that the axis of rotation is fixed with respect to the vehicle. Changing the angular velocity of the wheel changes its angular momentum, and this demands an equal but opposite change in the angular momentum of the vehicle proper.There's mention of the wheels moving at around 6,000 rpm. Is orientation changed by pivoting the axis (gyroscopic precession) of the wheels or by angular acceleration (torque) of the wheels?
Good question! The Hubble is also outfitted with magnetic torquers. Torquing the vehicle one way with the magnetic torquers and in the opposite direction with a momentum wheel that has an out-of-range angular momentum will result in zero net torque to the vehicle as a whole. There is however a non-zero torque to the momentum wheel, bringing the wheel's angular momentum back to its proper operating range. Angular momentum is of course conserved. The momentum wheel is transferring angular momentum to/from the Earth's magnetic field with the help of those magnetic torquers.Since you mention fixed axis, then I assume it's angular acceleration. If it's angular acceleration, then how is the angular velocity kept within some reasonable bounds?
The orientation of satellites is crucial for their proper functioning. It allows them to maintain a stable position in space, which is necessary for communication, navigation, and data collection.
Satellites are oriented using a combination of thrusters, reaction wheels, and gyroscopes. These components work together to adjust the satellite's position and maintain its stability.
Having a specific orientation allows satellites to point their antennas and sensors towards Earth or other objects in space. This enables them to gather and transmit data accurately.
Scientists can control the orientation of satellites using ground-based control stations. These stations send commands to the satellite's onboard systems, which then adjust its orientation accordingly.
Yes, the orientation of satellites can be changed if necessary. This is done by sending new commands to the satellite's onboard systems to adjust its position, velocity, and direction.
