| Thread Closed |
Math problem - solving for a variable |
Share Thread | Thread Tools |
| Aug13-10, 07:22 AM | #1 |
sqrt(2x+4) = sqrt(6x+1) - 1 I Need to solve for x, but cannot seem to get the same answer as the text. (Ans. x= 5/2) 3. The attempt at a solution sqrt(2x+4) - sqrt(6x+1) = -1 square both sides (2x+4) - (6x+1) = 1 -4x-3=1 -4x=4 x=-1 ?? I know I must be doing something wrong, it has been a while since I have done this sort of problem. Thank you for your time. |
| Aug13-10, 07:30 AM | #2 |
Your mistake is in thinking (a-b)2 = a2-b2, which is what you did when you squared the lefthand side of the equation. You need to multiply it out correctly.
| Aug13-10, 07:56 AM | #3 |
Im still not there yet:
My new attempt: ![]() I cant seem to get rid of the sqrt (x) i know sqrt(12x) = 2*sqrt(3x) |
| Aug13-10, 08:08 AM | #4 |
Now you're making even more mistakes. First,
[sqrt(2x+4)-sqrt(6x+1)]2 ≠ (2x+4) - (6x+1) Second, sqrt(a+b) ≠ sqrt(a)+sqrt(b) which is what you're doing going from the fifth line to the sixth line. You were, however, correct when you said earlier that (sqrt(2x+4))2 = 2x+4 The problem is actually a bit easier to solve if you square both sides right away: (sqrt(2x+4))2 = (sqrt(6x+1)-1)2 To correctly calculate the righthand side, let a=sqrt(6x+1) and b=1. Then your equation becomes (sqrt(2x+4))2 = (a-b)2 Now FOIL out the righthand side and then substitute back in for a and b. |
| Aug13-10, 08:19 AM | #5 |
Im sorry, I am unable to see that. All i can see is black and faint white portions. Is it possible for you to take a screen shot and upload to image shack?
| Aug13-10, 08:31 AM | #6 |
I edited my previous post and took out the images. You should be able to read it now.
| Aug13-10, 01:25 PM | #7 |
I got it, thank you for your help.
It took a while to come back to me. I appreciate your time, thank you.
| Aug13-10, 01:34 PM | #8 |
Mentor
Looks fine.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Math problem - solving for a variable
| Good Book Of Math Problems / On Problem Solving | Science Textbook Discussion | 2 | ||
| Solving for a variable | Precalculus Mathematics Homework | 1 | ||
| Solving For A Variable | Precalculus Mathematics Homework | 5 | ||
| Solving for a variable. | Calculus | 7 | ||
| Graphic technique for math problem solving | General Math | 6 | ||
