Do electrons lose mass due to revolving around nucleon?
h20 bear
Does the nucleon and electron lose mass as a result of the energies they exert in a static state.
The electron constantly uses the electromagnetic force to keep it attracted to the nucleon causing it to revolve around the nucleon. So does it lose mass?
Similarly, does the nucleon lose mass through its use of the nuclear/electromagnetic forces?
Are quantum vibrations of the atoms calculated in it's energy balance?
Forces don't work that way; it doesn't 'cost' energy to exert a force. Bound electrons don't lose mass. (Actually, they gain relativistic mass due to increased momentum)
Yes, zero-point vibrational energy is taken into account when calculating the total energy of a molecule.
This confuses me in regards to Thermodynamics. If an electron and proton are separate and they eventually float together. The electron experiences an increase in speed and thus relativistic mass, won't this be a violation of energy conservation? Where is the loss?
No, the electron does not radiate any energy when it is bound to a nucleon, but the electron loses energy in the form of radiating energy (a 912 Angstrom UV photon) when it falls into the bound ground state. For example, the electron and proton masses (times c2) are about 511 keV and 938 MeV respectively, but when the electron is bound to the proton in a hydrogen atom, the mass of the atom is about 13.6 eV lower than the sum of the electron and proton masses.
See
http://en.wikipedia.org/wiki/Lyman_series
Bob S
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
