Thread Closed
Speed of Sound Calculations. Confused.
Share Thread Thread Tools
Sep12-10, 03:48 PM   #1
We have to prove the speed of sound using a ultra-sound emitter, connected to EasySense software which records the speed for it to travel to surface and back. Known data - Speed of sound is 337 metres a second at 20 degrees celcius. Also, the distance covered is, 3.4m or 6.8m there and back. The time is 0.010837 micro seconds. Micro-seconds are 1 x 10^-6. All answers must be given with a +- .
2. Relevant equations
Speed = Distance / Time
3. The attempt at a solution
Time: 10897 +- 14 (microsecs)
Dist: 6.8 +- 0.014 (metres)
Convert microseconds into seconds. 10897 / 1000 and then /1000 again.
= 0.010897 seconds
Speed = 6.8 / 0.010897 = 624.024961 metres per second.
Obviously, this is nearly double the actual speed of sound. Was I not meant to double the distance? But I'm pretty sure the time is for there and back so double distance was needed. Have I forgotten anything? Of course, there is a chance the Ultrasound was reflecting from a place not wanted, causing the distance to not be true.
Help much appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Sep13-10, 03:10 PM   #2
Quote by Astonix View Post
= 0.010897 seconds
You have very different times in 1 and 3 above. Could you also have misunderstood the distance?
Thread Closed
Thread Tools
Similar Threads for: Speed of Sound Calculations. Confused.
Thread Forum Replies
Acoustics: Sound Level Calculations Advanced Physics Homework 3
Wavelength of sound waves and speed of sound in air column Introductory Physics Homework 1
Velocity of Sound, speed of rock and return of sound Introductory Physics Homework 1
Speed of sound and sound detection lag between ears Introductory Physics Homework 5
Sound waves calculations General Physics 16
