Physics plane/wind speed problem
  • Thread starter Thread starter lmf22
    Physics Speed
The discussion focuses on calculating the wind velocity affecting a plane traveling south at 280 km/h, which only covered 180 km in one hour, resulting in a southeast direction. The user initially estimated the wind velocity as 215 km but corrected this by analyzing the components of the plane's movement. The correct approach involves calculating the north and east components of the wind vector using trigonometric functions, specifically cosine and sine for the 45-degree angle. The final wind vector magnitude is derived from the Pythagorean theorem, and its direction is determined using the inverse tangent function.
  • Understanding of vector components in physics
  • Proficiency in trigonometric functions (sine, cosine, tangent)
  • Familiarity with the Pythagorean theorem
  • Basic knowledge of wind effects on aircraft navigation
  • Study vector addition and resolution of forces in physics
  • Learn about aircraft navigation and the impact of wind on flight paths
  • Explore advanced trigonometry applications in real-world scenarios
  • Investigate the effects of different wind speeds and directions on flight performance
Aerospace engineers, pilots, physics students, and anyone interested in understanding the dynamics of flight in relation to wind conditions.
lmf22
A plane is headed due south with a speed relative to still aire of 280km/h. After 1 hour the plane covered only 180km and their direction is not south but southeast. What is the wind velocity?
Any help would be great. Thank you.
This is how I am approaching the problem but I am unsure if I am right.
1) I drew a simple diagram to illustrate the problem (see attachement).
2) Side A is 280
Side B is 180
Side C is 215.5
So, I would think the wind velocity is 215 km.
That is not really right because in an hour the plane has traveled only 127 km due south ((180 km)cos 45 degrees east of south) because it is flying into a diagonal headwind. It has also traveled east ((180 km) sin 45 degrees east of south). These are the same so the east component of the wind vector is the ((180 km) sin 45 degrees east of south) while the north component is 280km-(180 km)sin 45 degrees. To get the magnitude of the wind vector you square the north component of the wind add the east component of the wind squared and take the square root. Use the positive number, magnitude is always positive.
(N^2+E^2)^.5= magnitude of the wind vector
The direction is then the inverse tangent of the (east component divided by the north component) east of north.
atan (E/N), degrees east of north
  • · Replies 26 ·
