Help Undersanding The Voltaic Cell
  • Thread starter Thread starter coreluccio
    Cell
Zinc metal reacts with aqueous copper (II) ions through an electrochemical process that requires a complete circuit, which is typically established using a salt bridge and connecting wires. The salt bridge allows for the movement of ions between the two separate jars, facilitating the flow of electrons. When zinc is placed in a solution containing copper (II) ions, zinc donates electrons to the copper ions, reducing them to solid copper. This reaction occurs despite the physical separation because the ions can migrate through the salt bridge, maintaining charge balance and enabling the electrochemical reaction to proceed.
coreluccio
Alright, so I understand how it works, except that, I don't get how zinc metal reacts with aqueous copper (II) ions if they are completely separated by two jars. How can a copper (II) ion pull the electrons from solid zinc when it can't even physically collide with zinc?
Chemistry news on Phys.org
They have to be connected by a salt-bridge, and also another (usually) wire to complete the circuit.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
