| New Reply |
A wire under stress |
Share Thread | Thread Tools |
| Nov2-10, 10:37 PM | #1 |
A wire under stress
A steel wire of length 1.92 m with circular cross section must stretch no more than 0.210 cm when a tensile (stretching) force of 390 N is applied to each end of the wire.
What minimum diameter is required for the wire? Express your answer in millimeters. Take Young's modulus for steel to be Y = 2.00×10^11 . |
| Nov2-10, 10:56 PM | #2 |
Hello, johntuan! Welcome to PF! But per forum rules, before you receive help, you must show an attempt at a solution . Then we can provide assistance to help you obtain the solution, by seeing were you may have gone wrong. You should be familiar with the stress vs. strain or load versus elongation relationship for wires with given parameters of length, load, area, and Young's modulus.
| Nov2-10, 11:26 PM | #3 |
E=Stress/Strain
E=(force/area)/(Change in length/original length) E*(change in length/original length)= force/area area=force/(E*(change in length/original length)) PiR^2=(390N)/((2.0*10^11)/(0.0021m/1.92m)) R^2=((390N)/((2.0*10^11)/(0.0021m/1.92m)))/Pi R=sqrt{((390N)/((2.0*10^(11))/(0.0021m/1.92m)))/Pi d=2R then change into mm |
| Nov2-10, 11:45 PM | #4 |
A wire under stress
Well, that is a lot better, and correct. Nice work!
| New Reply |
| Tags |
| elasticity, fracture, static equilibrium |
| Thread Tools | |
Similar Threads for: A wire under stress
| Shear stress in Energy-momentum Stress Tensor | Special & General Relativity | 16 | ||
| Understanding Neuber's Law for static stress state to calculate plastic stress | Mechanical Engineering | 0 | ||
| Spring wire stress relieve | Materials & Chemical Engineering | 1 | ||
| Stress-energy tensor of a wire under stress | Special & General Relativity | 178 | ||
| Stress @ Proportional Limit, Ultimate Stress, Breaking Stress, etc. | General Physics | 0 | ||
