Lagrangian and Action question?
  • Thread starter Thread starter Livethefire
    Lagrangian
The discussion explores the origins and applications of the Lagrangian and action integral in physics. The Lagrangian was developed through variational calculus, focusing on the relationship between kinetic and potential energy, typically expressed as L = T - V. The action integral arises from summing the Lagrangian over a trajectory, leading to the principle of least action, which states that the action must be minimized. In quantum mechanics, the Hamiltonian is preferred over the Lagrangian because momentum, rather than velocity, is the observable quantity, necessitating a transformation from Lagrangian to Hamiltonian dynamics. Conversely, in quantum field theory, the Lagrangian formulation is more commonly utilized.
Livethefire
Ive been doing some research on the title concepts...
And would love it if someone could answer some questions because I can't seem to find the answer anywhere.
1) How was the lagrangian found? I know its kind of defined, and there are other lagrangians- but is there an idea behind it or was it trail and error?
2) Similarly, how was the action integral found? Or were they just trying to sum the lagrangian over the entire trajectory... for fun, and found that it needed to be minimum?
3)Finally a general question, are there problems that the lagrangian would overcomplicate? (ie Newtons laws are easier to use?) And why specifically do we see the hamiltonian more readily in Quantum physics, as opposed to the lagrangian?
Thank you for anyone who sheds light on these questions. Like I said, I can't seem to find a direct answer where I have looked.
Thanks.
I suggest you first look at the very nice wikipedia article on http://en.wikipedia.org/wiki/Joseph_Louis_Lagrange" . He originally developed the Variational Calculus then applied it to Newtonian Mechanics.
As far as how the action is found, one may begin by considering the form of the Eulier-Lagrange equations to the specific equations of a the system in question. Then observe the form the Lagrangian must take to yield those E-L equations.
For general mechanical systems one can typically define separate kinetic energy, T and potential energy V. The Lagrangian which then gives the proper energy conservation is L=T-V.
In more speculative settings one makes use of http://en.wikipedia.org/wiki/Noether%27s_theorem" which she developed at the behest of Einstein. It states that any symmetry of the Lagrangian will manifest a corresponding conserved quantity. One then selects forms of Lagrangian's with the postulated and/or observed symmetries seen in nature. Given sufficient symmetry one has a pretty restricted class of lagrangians one might consider.
Finally as to your question as to why we use Hamiltonians more so than Lagrangians in QM, that in part is because particle velocities (and their correspondents in general systems) are not in and of themselves observables of QM systems. Rather it is the momentum which is.
The transition between x, dx/dt <---> to x,p is what is known as a Legendre transformation. When applied it transforms the Lagrangian to the Hamiltonian and the Euler-Lagrange equations to Hamilton's equations for the dynamics.
One is effectively introducing an extra set of independent variables while reducing the order of the dynamic equations. The fact that particles in QM do not follow classical paths as such and that velocities are not quantum observables, dictates a position,momentum (operator) representation which in turn best fits in the Hamiltonian scheme.
On the other hand, working in QFT one rather makes more use of the Lagrangian formulation than Hamilton's.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
