| New Reply |
Help with Euler's Method in Matlab |
Share Thread | Thread Tools |
| Nov6-10, 03:18 PM | #1 |
Well, I'm having problems with this script, I'm taking my first course on differential equations, and I am trying to write a script that approximates the values of the solution of a differential equation, and compares them to the exact solution using a table of values, it must also calculate the error, the problem is that I cannot make the table to appear using a column for each variable, instead, the values are spread horizontally and everything is pretty messed up, Its the first time I use Matlab and I might have a lot more mistakes, can anyone help me? 2. Relevant equations the equations are pretty simple, they are in the bottom of the script I wrote 3. The attempt at a solution this is what I wrote function [t P] = Euler(t0,P0,L,N) % Nombrando la función y estableciendo los datos necesarios Close all; h=L./N; % estableciendo tamaño de paso t=[]; P=[]; % t y P son vectores vacíos t(1)=t0+h; P(1)=P0+h.*f(t0, P0); % Estableciendo los primeros componentes de t y P for n=1:N-1 t(n+1)=t(n)+h; P(n+1)=P(n)+(h.*(f(t(n), P(n)))); end Paprox=P; Pexacta= SolucionExacta(t); error=abs(Pexacta-Paprox); % Para imprimir la tabla fprintf(' t Paproximada Pexacta error \n'); fprintf('---------------------------------------------------------------------------------\n'); fprintf( '%10.5f %10.5f %10.5f %10.5f', t ,Paprox, Pexacta, error); % Para graficar plot(t,P); hold on plot(t,Pexacta); figure; plot(t, error); end function ret=f(t,P)%para insertar la ecuación diferencial que deseamos resolver por aproximación ret=(0.0225.*P-(0.0003.*(P.^2))); end function f=SolucionExacta(t) % Para establecer la solución aproximada y hacer comparación f=(0.5625.*exp(0.0225.*t))./(0.015+(0.0075.*exp(0.0225.*t))); end |
| Nov6-10, 04:16 PM | #2 |
The issue is you're printing arrays. You need to write your print statement in a loop, looping your values.
| Nov6-10, 04:26 PM | #3 |
As viscousflow said you'll need a for loop to print the array. Might help to add a 'next line' command into your code \n
Here: fprintf( '%10.5f %10.5f %10.5f %10.5f \n', t ,Paprox, Pexacta, error); |
| Nov6-10, 04:56 PM | #4 |
It worked!, thanks a lot
| New Reply |
| Tags |
| euler's method, matlab, table |
| Thread Tools | |
Similar Threads for: Help with Euler's Method in Matlab
| Euler's method/matlab | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Matlab Help!! Euler method | Engineering, Comp Sci, & Technology Homework | 10 | ||
| Euler methond and the improved Euler method | Differential Equations | 4 | ||
| Euler Method in MATLAB | Mechanical Engineering | 0 | ||
| Euler method | Differential Equations | 12 | ||
